More HP with Davies Craig Electric Water Pump (EWP) & Electric Booster Pump (EBP)
Old Dec 27, 2003 | 07:19 PM
moondragon's Avatar
Any horsepower liberation from the crank pulley and to the wheels from these products ?
http://www.daviescraig.com.au/
I would imagine that these would benefit engines with a separate belt driving the water pump ie. remove the water pump / belt and put in one of the EWP. The M111 and M271 engine has the same belt driving the supercharger / alternator / waterpump ?
How about those who underdrive the waterpump pulley to get more hp ? > wouldn't the EBP provide a "fail-safe" to ensure sufficient water cooling for our supercharged engine ?
Lastly anyone with experience with these products ?
Thanks.
Old Dec 27, 2003 | 11:54 PM
levelr123g's Avatar
our cars already have these on them, look near the radiator fill resivoir.
Old Dec 28, 2003 | 01:55 AM
moondragon's Avatar
you mean that our water pumps are not driven by the crank ie. electric water pump ?
or that we already have an electric booster pump ?
Thanks.
Old Dec 28, 2003 | 03:23 AM
DCXdynodog's Avatar
2003 C230K, 6 spd, Brilliant Silver, C-5, C-7, CD changer
Thanks.
The small electric pump at the reservoir is for the REST function, which keeps the car warm (for a short time) while not running.
Water pump for cooling is mechanical, and no, you won't gain a bunch of power by switching to electric. The alternator has to work harder to supply power for the electric pump and it takes HP to drive that to. If anything it is likey to be less efficient.
Old Dec 28, 2003 | 01:00 PM
Lynn's Avatar
Re: More HP with Davies Craig Electric Water Pump (EWP) & Electric Booster Pump (EBP)
The M111 uses two belts to drive the accessories, while the M271 uses one belt to drive everything.
