MJ50's W203 Mod Fever (OEM Retrofits)
#536
'09 A4 S Line
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Did you ever notice a "whirring" sound coming from your rear drilled rotors? I don't remember hearing it on my last set, but that was a long time ago. I definitely hear it after having them installed this weekend, but figure it will go away after they wear a little.
#537
05 C230K SS 6MT, 00 Audi TT 180Q 5MT
Dang...from one problem to the next!
i had drilled and slotted rotors on my TT and got the humming noise, i had put hawk hps pads on as well and but the sound did go away after about 200 miles or so of driving...just my .02
#538
'09 A4 S Line
#544
MBworld Guru
white and whiter
take the wheel off and take a measuring tool to the endlink. it the only way you'll be able to tell if you are not sure. 12mm one is thicker all around, not just the difference in bolt size.
#549
C55 ///AMG, 535xi
I got the "new 2003" bar, with the pre-attached poly urethane bushings, dealer said I needed only 1 bracket. I insisted in using two, they're sending me another one.
Original 22mm rear stablizer bar,
203-326-15-65 with bushings 203-323-16-85
replaced with new stablizer bar with pre-attached poly urethane bushings
203-323-44-65 with bracket 203-323-27-40
heres my share of pics...
![](http://img253.imageshack.us/img253/4853/dsc03994xj0.jpg)
front sway bar(bottom@16mm) rear sway bar(top@22mm)
![](http://img514.imageshack.us/img514/2958/dsc03995hc7.jpg)
rear bar with pre-attached poly urethane bushing (old rubber bushing next to it)
![](http://img363.imageshack.us/img363/7/dsc03996qa1.jpg)
with the new bracket on
![](http://img514.imageshack.us/img514/4306/dsc03997ob0.jpg)
with the new bracket off
#550
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
The one I had for the front was exactly the same as advans (which seems to be a 240 front endlink number). We'll see what happens tomorrow. Just remember, I got those part numbers from someone else.
