lowering springs or suspension
2002 C 240
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hey, what's up guys
Are there any suspension setups or lowering springs that will drop a C240 by 2".
If I'm not wrong the H&R cupkit has a 2" drop right, are there any other besides H&R cupkit?
And can someone post their C-class sedan with 2" drop or 1.5" drop.
Ive got the cup kit on my C320.
I already have the sport package so the drop was not exactly 2.0 inches.
More like 1.75 or so.
The rear is fine but i wish the drop in the front was a little more so the car sits evenly.
The cup kit is a great buy but getting the coilovers( if you got that extra cash to spend) would be even better.
The cup kit will allow you to go as much as 2.2 in the front and 1.7 in the rear...
calvin
calvin
2002 C 240
calvin, thanks for the pic. Nice car btw. I like your wheels, what kind are those?
Any other pics that I can see with 2 inch drop. Uhhh....how 'bout 2 inch drop on stock wheels. Are there any of you out there rollin on this setup.
C200 Kompressor
Man, I envy your rims calvin!!! Those are 18" OZ F1-something, right? I really, really want those
. What tires do you have? Is the ride much rougher than with standard rims/tires?
2002 C 240
yea.....I saw it.
That is nice dude. Did you do something with the front, because it the drop looks even with the rear. Should the front be higher than the rear.
Thanks harris
Thanks harris
The car's current setup is stock AMG shocks + H&R springs (from the cup kit). I didnt do anything to the front but I've put a Dot 4 (the thickest one) shim perch on the rear just to balance it out.
I am seriously considering Kleemann or Renntech suspension system.
The only thing that i can think of which will cause a warranty problem is the shocks. You can always change the aftermarket springs back to yr stock springs IF they refuse to cover the warranty. Otherwise, I dont think there's a problem.
2002 C 240
Originally posted by BigB333
does dropping your car like that void the warenty?
You have Cold Air intake....."We will void your warranty for that"
and so on and so forth
But what I understand is that they can't void your warranty just like that. If a problem happens and after they traced it they found out that your modifications is the cause of that problem, then they won't fix it for you using your warranty.
But if your modifications didn't cause the problem, then they should use the warranty to fix your car.
I put a cat-back exhaust and a K&N drop in filter in my VW, the dealer are pretty OK with that, although they told me not to mod the car or else it will void the warranty.
hope it helps
thanks guys
the wheels are O.Z. F1 Plus. 18x8
The tires are in front are Michelin Sport 225/40.
The tires in the rear are P7000 235/40
The ride is not as good as it was when the wheels were stock but Im not complaining.
The FUN FACTOR more then compensates for it.
calvin
calvin
2002 C 240
ok born2drive, so basically they tell you whatever you do will void the warenty, but they really wont?
I once burned my headlight harness in my VW Jetta, because I changed to high wattage bulbs. I knew it for sure that my bulb was the cause of the problem, so I changed it back to stock and brought it to the dealer. I played dumb as if I'm surprised that this thing happened. Although they seemed suspicious, they can't prove that it was my fault, so they changed it for me anyways......
