I Can't stand this Bose system anymore!
Guest
Posts: n/a
![Thumbs down](https://mbworld.org/forums/images/icons/icon13.gif)
It has finally come to a point where I am just DISGUSTED with the the Bose system. I rarely even listen to music anymore in my car because of this.
I remember I made a thread about replacing the audio but I think it was deleted by the downtime.
I guess I should start by looking at some HUs? Alpine or Pioneer would be the brands of choice.
How much of a difference Can I hear? I Dont have a fortune to spend I am willing sacrifice some money
I just want some QUALITY, clear, music with some Good Bass! Is this too much to ask?
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
01 C200 Kompressor, 02 C32 AMG
Have you got Audio10 CD right now??...if not maybe that should be your next step. If you already have Audio10 CD then replace the factory speakers, add a sub or two along with the amp(s). This way you still can use the buttons on your steering wheel.
The factory Alpine made Audio 30 cassette radio is pretty flat sounding. Come by and listen to my MB Audio 10 CD, it's made by Becker, you can get it for about $250 and sounds much better, so much bass you will likely not want to keep it at the full bass setting like you probably do with your current radio. Check my website for a link to the Audio 10 manuls and install instructions.
The True OG Modded out W203
Originally posted by Noble C320
So Audio 10 would be a BIG improvement?
Even better than aftermarket alpine or pioneer stuff?
I dont mind losing steering wheel controls or the aftermarket look.
Just the best improvment in sound.
Guest
Posts: n/a
Originally posted by LorinserCClass
It depends on your budget man. You want the BEST sounds fork over the cheddah for the top of the line alpine decks, mc intosh amps etc. Or for a modest amount Mbquartz components alpine deck and some PG amps. Best thing you can do also is hear other peoples set ups...
I am not buying the subs, amps etc for now. Maybe later on.
What I am basically asking is if the standard HU is replaced by an Alpine HU then would It improve alot or am I just wasting my money?
Thanks alot everyone
Guest
Posts: n/a
Originally posted by mj50
noble,
if u intend to get aftermarket HU, then u should get an amp also.
since u have bose, i'm sure it'll sound better than stock speakers after HU (and amp) upgrade.
noble,
Just a Question... Are there specific HUs that are incompatible with the our Cs? Or incombatible with the bose speakers...
I don't care about the lose of steering wheel controls btw.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
bone stock E55 AMG
almost all HUs should be compatible with our C.
not sure about Bose, but i'm sure that won't be a problem.
i wanted aftermarket also, but i want to keep everything look as "stock" as possible.
Guest
Posts: n/a
I thought about the Stock look thing. I dont think it will look bad. It will sure look cool at night.
Now to decide on a model. How much is a good price for a good HU?
Administrator
Thank you for your useless post
C- 230 Kompressor,C2,C7,Black,JL sub,A/D/S/ amps,Alpine hu and changer
I don't think the bose speakers will work with a aftermarket hu, I think the bose speakers are 2.2 ohms, and most standard hu's run 4 ohm speakers ,I replaced everything I could not stand the factory system from day one.
Guest
Posts: n/a
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
You had the bose too? How much did you spend in all stripping it and getting all the new stuff if you dont mind?
MBworld Guru
white and whiter
I think we need two 9 inch sub like the Harman Kardon system on my old 2000 328Ci (it's an option on all 3-series). That thing had MAD BASS and you can turn off the sub individually too.
we only get one sub because stupid MB designer had to put the medkit on the rear deck. The medkit for my old 328Ci was in the trunk.
Administrator
I thought that the subs were 6 x 9 in those BMWs. I know that they are a lot deeper than that MB sub which is wedged in back there. Clue me in if you don't mind.
Listen to an Audio 10 before you spend the $1,500 it's going to cost to pull out all the Bose components (speakers included as they won't work with aftermarket HUs) and replace them with something that may reduce the value of your car at resale time. The current opening is convex and trapezoidal, it does not look good with a $15 bezel kit and a flat din size radio. The texture doesn't really match up well. The display will not match the color and light intensity of the surrounding components so it will stick out and be an obvious intrution. I can see doing this for something really special but not for a $300 HU. If you are going to do it, go to a top rate shop and be prepared to do it right ($$$).
Guest
Posts: n/a
All right Audio 10 it is! So Audio 10 along with the Bose will be a significant difference??? I really don't like the look of the Audio 10. It looks extremely bland IMO. But I will go ahead email Steve if it’s really worth it...
MBworld Guru
white and whiter
Originally posted by amdeutsch
For MY03 the kit moved to the trunk as well.
The diference is that the Audio 10 has a bass range of +-12db instead of the +-10 that the Audio 30 has. Not to Mention an apparant better/cleaner signal output. Yeah it does not look good but all your Bose equipment still works then. With an Aftermarket Head Unit you would need to replace all speakers and wire into the door for those speakers. Or tap into the wires going to the doors, still a pain in the ***. Not fun. Try to find someone with an Audio 10 to compare if you can. It will make you decision a lot more easy.
2008 VW GTI
You'll get more volume and maybe more bass from the doors.
IMHO, the stock Bose sounds better than the Audio-10. Speed sensitive volume and audio-pilot don't play well with the Audio-10 either. It works, but is more erratic.
