CRANKSHAFT SENSOR NO SIGNAL
C180 KOMPRESSOR
I have a C180Kompressor (W203 - M271.946) AUTO gearbox with fault 'NO SIGNAL' from crankshaft position sensor.
I replaced it by an original crankshaft sensor (MB A003 153 28 28 = BOSCH 0 261 210 170) but stil having no signal when engine runs.
The sensor has 675 Ohm but when engine is running those ohms disappear.
I connected two cables direct to the sensor to avoid contact with the ECU and is exactly the same: 675 Ohms until the starter runs, at that moment the read is zero Ohm.
Grateful for all the help I can get
