Automatic volume??
Old Jan 14, 2004 | 02:55 PM
JonixC320's Avatar
C320 Coupe
Automatic volume??
Is there a way I can turn off the automatic volume (where the radio/receiver listens and adjust to surrounding noise)?
...I installed a couple of subs (800watts) and when it pumps out bass and makes a lot of vibration, I think the receiver/mic picks it up as noise which makes the volume go up (way up). This only occur when a lot of bass is produced.
Has anyone encountered this kind of situation?
Thanks!
Old Jan 14, 2004 | 03:09 PM
Blake P's Avatar
'09 A4 S Line
This features must be turned off by the dealer. I think it's a two step process that can be done pretty quickly and easily. There was a very informative post about exactly what needs to be done, but I can't seem to find it now. Maybe someone can locate it or post the info. here. I plan to have mine turned off at Service A.
Old Jan 14, 2004 | 04:43 PM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
Yes, Star Diagnostics controls that option. The dealer can control the decible amout too. If your is going up too much you can dial it down, or de-activate it. Mine is turned down to 3 decibles. I like it on. They should do this free of charge. Mine did.
Old Jan 14, 2004 | 08:01 PM
R4ND0M_AX3's Avatar
C230
I assume you are talking about the BOSE Audiopilot. There is a microphone to the right of the mirror in the headliner. You can feel a little hole when you run your finger over this area. Pop open the dome light and you can unplug the mic.
This is different than the speed sensitive volume setting found in Star Diag.
There was a thread on this about a billion years ago with photos from someone (maybe it was on the 'other' site).
Old Jan 14, 2004 | 11:34 PM
levelr123g's Avatar
yes unplug the mic, it works
levelr123g's Avatar
Old Jan 15, 2004 | 12:11 AM
Blake P's Avatar
'09 A4 S Line
How difficult is it to pop open the dome light? I don't wanna break it by accident
Old Jan 15, 2004 | 08:22 PM
JonixC320's Avatar
C320 Coupe
Great!
Thanks for all your replies!
I'l try unhooking the mic. I just hope I dont break anything.
BTW, after unhooking the mic, would the computer read it as a mulfunction?
Old Jan 15, 2004 | 08:46 PM
Lynn's Avatar
Re: Great!
No one who has disconnected the mike has reported any error messages of the multi-function display.
Old Jan 15, 2004 | 10:16 PM
Blake P's Avatar
'09 A4 S Line
Is there a trick to opening the dome light? I can't seem to figure out an easy way to get it open.
Old Jan 16, 2004 | 12:31 PM
JonixC320's Avatar
C320 Coupe
Use a flat head screwdriver and carefully pry the cover. Start from the side closest to the mic.
Got it open... I found a couple of wires (thick-end connected with the dome switches, thin-runs inside to god knows where). Which one should I disconnect? I felt (couldn't see) they're both connected to the black thing where the mic is. HELP.
Thanks again!
