Guys Need Help Asap!!
Old Jan 15, 2004 | 06:58 PM
C kL@Sse's Avatar
hey guys someone wants to sell me their CARLSSON 2/5 wheels..the only thing im unsure is if they will fit!!! they are 19x9 all around.... i know the rear is NO PROBLEM because other have succeded in putting 10'z in the rear..,but will 19x9 fit the front??? please help!! thanx in advance!!
Old Jan 15, 2004 | 07:00 PM
jo17jC230's Avatar
2008 C300 Sport
thats a bit wide to be putting in the front... whats the offset?
Old Jan 15, 2004 | 07:06 PM
C kL@Sse's Avatar
i am not sure,,but it came off a s430..he is only asking for 1500 w tires w 2 piece in good condition..seems like deal if i can get them to fit..should there be a BIG difference between 19x8.5 and 9??
Old Jan 15, 2004 | 07:32 PM
jo17jC230's Avatar
2008 C300 Sport
yes it makes a BIG difference in the front... its not gonna fit...
Old Jan 15, 2004 | 08:02 PM
Xeon's Avatar
i thought the offset between S and C is very diff?
Old Jan 15, 2004 | 08:28 PM
C kL@Sse's Avatar
Unhappy
thx for the info guys
Old Jan 15, 2004 | 08:44 PM
Lynn's Avatar
You can't use those wheels. The offset is wrong. The lug bolts are wrong. And the widest front wheels you should use are 8.5".
Old Jan 15, 2004 | 09:33 PM
C kL@Sse's Avatar
thx lynn..but i think ill take it to the shop to try..i mean when i bought my brabus wheels they told me i couldnt put 19x9.5 in the rear..I sure proved them wrong..and now we have people putting 19x10 in the rear..im going to give it a shot..i know we're not suppose to try anything above 19x8.5 in the front but it might work.. again thx for the help guys..
Old Jan 15, 2004 | 09:38 PM
mbphreak's Avatar
woah 9 in the front...watch out when taking turns, you might just lose your fender well...g luck
Old Jan 15, 2004 | 09:43 PM
Lynn's Avatar
C kL@Sse, attempting to drive your car with those wheels on it is dangerous. Those wheels require a bolt with a 14mm radius hemisperical surface. Your car uses 12mm bolts. Those bolts won't provide enough clamping force and will quickly loosen. That results in damage to the bolts and wheels, which may lead to the wheels falling off the car.
And there is no chance that a 9" wheel will work on the front.
Old Jan 15, 2004 | 09:48 PM
C kL@Sse's Avatar
Unhappy
eeeeek!!! thx lynn.. i will not try it...what a good deal..wasted!!
Old Jan 15, 2004 | 09:50 PM
C kL@Sse's Avatar
mbpheak, hope you dont mind me asking,but how much in brabus accesorries have you spent?.. by the way awwwwwesome car!!
Old Jan 16, 2004 | 01:27 AM
Harris's Avatar
The offsets are wrong and the wheel is too wide for the front - true.
But the wheels require 14mm bolts is not true. All Carlsson, Brabus, Lorinser wheels have only one measurement for the bolts. IF the offsets between the S and the C are the same, they will be interchangable AS LONG AS you use the respective bolts, i.e. 12mm for the C and 14mm for the S.
Old Jan 16, 2004 | 01:53 AM
Lynn's Avatar
Oops, I was thinking of OEM wheels.:o :o
Old Jan 16, 2004 | 12:10 PM
mbphreak's Avatar
CKl@sse...much more than I should have, that's how much next major mod is dropping an e55 or clk55 engine
Old Jan 16, 2004 | 12:14 PM
LorinserCClass's Avatar
The True OG Modded out W203
u my friend have a problem
lol but let me know how much it costs!!
Old Jan 16, 2004 | 12:36 PM
mbphreak's Avatar
Why? You interested to do it? hahahaha, you my friend have a problem too.
Old Jan 16, 2004 | 01:01 PM
man i want my car to VROOM not put put anymore
Old Jan 16, 2004 | 01:06 PM
mbphreak's Avatar
I thought you were getting blown?
Old Jan 16, 2004 | 01:27 PM
lol i did
50 HP for 10K isnt appealing to me anymore...
Old Jan 16, 2004 | 03:30 PM
C kL@Sse's Avatar
guys the offset of the wheels are +35 for all four 19x9...the guy had to clafify that they came off a 2001 audi a4.and not off the s430.so these WILL fit right?? i thought he meant S class because he said he had a S...
Old Jan 16, 2004 | 04:39 PM
mbphreak's Avatar
ckl@sse they will fit...you just won't be able to turn properly...maybe 2 turns of the steering wheel at most.
anything more will damage the fender and fender well...i think...g luck.
Old Jan 16, 2004 | 05:42 PM
Lynn's Avatar
Audi wheels have the wrong centerbore. You will need adaptor rings with a 63.3mm centerbore. And the 9" wheels still won't fit on the front. I think they'll rub in the struts.
Old Jan 16, 2004 | 06:13 PM
jo17jC230's Avatar
2008 C300 Sport
9" is way too wide to be running in the front.
