Where can I buy the In-Dash CD?
Or do you want the MB unit sold outside the US. The Audio 10 is available at any UK dealership for less than 300 pounds. The MB Dealer in Stuttgard speaks english and will ship to you.
For used ones check E-Bay, there's always a bunch for sale there. Not the US E-Bay. Try http://www.ebay.de/ and search for Audio 10. They seem to go for about 150 euros.
Thanks - that's exactly what I was looking for. And these Audio 10's fit in the C-class? Also - why are they so cheap? I mean...under $200! Is something wrong with them?
The flip-away display is just sooo cool; although I haven't played a single tape yet since I got the car, I keep playing with and showing off that awesome feature. :p
theLeland, be careful, not all Audio 10's have CD players. Use babelfish to translate the German to English. Most have pictures so you can weed out the cassettes. BTW, 200 Euros is about 176 and shipping from Germany is comperable to UPS within the US.
A CD is a CD so that's not a problem. FM stations in Europe are even decimal (ie. 101.2) and ours are odd (ie. 101.1) but it still works fine. AM can be tuned to a specific frequency but the scanning is close but not perfect and their AM frequency range only goes to about 1600Khz instead of about 1700Khz in the US. Also the Audio 10 displays the station name on the display and on the dash display for radio stations that support it. This is a cool feature on the Audi radios. It will work with the CD changer but not the integrated phone.
If you check around other posts there's one person that has it and he says it sounds better than the Audio 30 we have and is very happy with it.
I would get one but it's too late for me as I already got the changer.
Also - what's the unit for the E-class called? I want to get one of those too...
Here's a correct one.
http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=1714295662
Happy shopping!
The radio works fine except every station plays polka and oom pa pa music.
If I were you, I would try and get the BE6021. I know it works, I know it is plug and play, and that it works with the steering wheel controls and the MFD. The FM works fine because it tunes in steps of 0.1MHz (so it seeks and displays RDS station names), and the AM is OK for the stations to which I listen. It also looks great in the car, as the front panel is designed to match the climate control panel below it. It also has LW and SW, but I'm not sure what you'll receive on these.
It has speed sensitive volume and an external phone mute input. It also has the ASC feature which quickly scans the FM band and temporarily stores the strongest stations in the presets. Selecting ASC again restores your original presets.
I am still hoping that a European reader of this message board will be able to post the sections of the owner's manual that pertain to this unit, as I'm sure there are additional features that I have not uncovered.
If this radio came out of a 2002 C230 coupe why would it not fit one in the US? Are the radio openings different in Germany?
It seems that there are different models of the Audio 10. Some of them look totally different.
The model number I've quoted was read directly from the unit's sticker, but the picture you've attached is identical to the BE6021 I installed, right down to the box!
If this is an audio 10, then my apologies. Trust MB to call different things the same name.
By "wings" I mean the two lugs that are mounted on the sides of the unit, just behind the front panel. THe audio 10s I saw on Ebay didn't have these - probably for the old model.
So I guess if it looks like the one in your picture it should be OK.
Sorry for the misinformation.
BTW, have you installed one yet?
Cheers
Raymond
Is it necessary to get the radio code for installation?
Anyway, I am a european reader, and have this unit factory-mounted in my car. Mine came with a manual, so feel free to ask me questions!
One feature I don't think was mentioned here is that there is built-in support for traffic-info. When a selected station (with RDS-broadcasts) sends a traffic-related message these messages will interrupt the original radio-playback (and even interrupt CD-playback). There is a separete volume setting for those intterupting messages (I think it is +3 +6 and +9 dB).
Didn't your unit come with a users manual???
No, for some reason my radio came all nicely boxed and packaged, but without a manual. I thought this may be because it would be in the owner's manual like the cars in the US.
Thanks for the assistance. I have the following questions:
1. What is the button that looks like a speaker with a line through it? I thought it was a mute button, but when I press it it says "No TP". Is this maybe the Traffic Program?
2. Are there any hidden menus for adjusting any of the radio parameters, for example the AM MW step and speed sensitive volume?
3. Does the CD player have anti-skip read ahead memory?
4. Is the manual part of the car's owner's manual or separate?
5. Does it support the CD changer? If so, how, and, which makes?
6. Are there any other additional options for this radio, like external amplifiers and sub woofers?
As the previous poster stated, RDS is huge in Europe and even in South Africa, but pretty unused here. Probably because most of the US is as flat as a pancake and one transmitter will service an area as big as Texas.
Many thanks.
Raymond
This is a mute-button, but it will only mute in radio-mode, and not in CD-mode. In CD-mode this button works as an on/off-switch for the Traffic Program feature.
No, unfortunately not. I think the speed sensitiveness can be adjusted by your dealer though. This is not mentioned in my manual.
No. You can't scan a track (if that's what you meant). Personally, I think this sucks!
It's a separate one.
Yes, it supports the CD changer. Guess it will ONLY support the mercedes original changer though.
I don't have the changer myself, but I think I've read in anoter post, that you select CD with the up/down-arrows, and track with the left/right. Or maybe it was the other way around... Will have to look it up.
I think (not 100% sure, I will have to scan my manual which I don't have access to right now) there is built in support for the BOSE-system.
The anti skip memory means that the CD player reads ahead from what you're currently listening to, and buffers it into memory, and plays it back from memory so that if there is a skip due to hitting a pot-hole in the road, there is no break in the sound. Most personal CD players like Sony DIscman that cost more than $50 have this feature, the price corresponding to the number of seconds of memory. My friend has a CLK430 with the Bose CD, and it skips if you fart in the car, it's so sensitive!
Any way you could get a price?
[/B]
Thanks for the help and the quick response. I'm sure many others on this site will be happy for the additional information to help them decide whether to take the plunge or not.
BTW, your English is excellent, probably a lot better than my Swedish! Are you originally from somewhere other than Sweden? Why a MB, not a SAAB or Volvo?
Cheers and thanks again
Raymond
I'm not so sure about that, you got both Volvo and Saab correctly spelled
. Anyway, thanks man! My self-confidence is now back on top!
Nope, I guess I just had a fairly good english teacher
.Why a MB, not a SAAB or Volvo?
Well, they are both nice cars, but EVERYBODY has them, so why go with the flow???
Cheers!
