ECU Removal
Old Jan 24, 2004 | 11:23 AM
Kotsios's Avatar
C180K (M271)
ECU Removal
I planning to chip my ECU and I want to know how can I safely remove the ECU (M271 engine) from my car. Pictures would be very helpful.
Any other relevant info are welcomed.
Thank you in advance.
Kotsios
Old Jan 24, 2004 | 12:59 PM
gmabm's Avatar
Re: ECU Removal
Kotsios
Its lot easier to remove the ecu from a M271 than M111. Its right there under your nose when you open up the bonnet. No tricks!
Old Jan 24, 2004 | 03:31 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Pics have already been posted before. Just use
Old Oct 18, 2010 | 11:11 AM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
anybody have any recommendations on how to remove the ecu from the m271? I took a look at it this morning and couldn't even fathom how the heck one would remove it in the little room there is on the side of the unit to undue the torx screws...the front 2 it seemed i might be able to get a socket wrench with a torx adapter attached but the back 2 there was no way i could get the adapter plus the wrench down in there...any suggestions? or anyone done this before?
Old Feb 3, 2011 | 05:23 PM
Midnight Koop's Avatar
CL203
have there been any threads posted for this? i can't seem to get to the back two screws and want to make sure i'm doing this right...
any of you guys have the official removal instructions? all i can find are instructions for other engines and its not helping...
thanks,
Old Feb 3, 2011 | 05:50 PM
mikey1011's Avatar
2003 c230 kompressor
Its pretty easy to remove, once the plastic housing comes out. Essentially remove the top screws from the intake, take out the filter, and also the front ram air pipe. If you look where the cone filter connects, from the top you should see 2 torx bolts, its kind of hard to find the proper socket because the plastic surrounding requires a special extended bit. I used I think a 9mm with a 1/4. Now comes the tricky part. I recommend using a set of wire clamp removers. Basically there is a hose underneath that connects to the supercharger that you will not be able to get to unless you invest in this tool. The flexibility of it allows for easy removal of spring clamps. It should take you about 10 to do, and then you can just push the plastic housing back and just pull up.
I dont have any pics sorry. Hope this helps
Old Feb 3, 2011 | 06:00 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
I found it easiest to just remove the whole airbox. Look for the MAF replacement DIY's - you only need to go as far as removing the airbox. The ECU is attached to the airbox with 4 torx screws. Not saying this is the only way, just what I found easiest to do...
Old Feb 3, 2011 | 08:48 PM
CL203
great thanks... i will try this method because it sounds more simple (i hope)... attached is a picture of the ECU still in the car... very inconveniently placed
Old Feb 3, 2011 | 10:26 PM
mtnman82's Avatar
The only tough part is the large diameter hose clamp on the other side of the MAF (near the firewall). I replaced the stock clamp with a 'normal' one (i.e. that you use a regular screwdriver on). Have fun!
Old Feb 4, 2011 | 03:48 PM
Nokiemon's Avatar
CLK55 AMG, SL55 AMG, C55 AMG
+1 on removing the entire air box assembly for access. On the M271, the fourth and lower level torx screw closest to the driver is a major ***** to get to without small tools, small hands, and alot of patience. It took me 15 minutes to remove the first three screws and almost an hour to get the last one.
When I removed the ECU for a buddy's re-flash on his M271, I took off the entire air box this time and was able to extract the ECU in less than 20 minutes. Took me less than 30 minutes to remove the air box, but I did not have to contend with small openings and chewed up hands (even with Mx gloves), so it was worth it to me doing it this way as opposed to trying to move the ECU on it's own.
Old Feb 4, 2011 | 03:58 PM
CL203
unfortunately, im doing this outside in the cold with minimal tools... if it doesnt go smoothly, i might just have them ship me cables.
i saw the instructions to remove the airbox and it seems do-able.. i just wish it weren't so damn cold out
Old Feb 4, 2011 | 07:42 PM
Nokiemon's Avatar
That is where the 100 proof Stoli shots come in handy
Seriously, the air box removal is a pretty straight-forward job and can be accomplished in less than 30 minutes. Trying to remove very small torx screws with very cold fingers can lead to missing screws, so if it warms up for you, try the air box route. Good luck.
Old Feb 4, 2011 | 09:49 PM
casper_c230's Avatar
Mercedes Benz c230
You'll have to share your technique w/me b/c it took me at least 45 minutes just to remove the hose clamp. I can imagine a flex drive can remove the torx screws. I'm not sure how the company did it, but they removed the ECU w/o removing the air box in about 30 minutes when they reflashed it. It's possible, but I'm just very doubtful that most people can remove the air box "easily." It was a pain in the ****. Thanks to swapping the crazy stupid MB clamp with a normal plumber's hose clamp, it'll be much easier the second time around. The first time is a @#$@# though.
It's a bit more helpful to post the link. STFF as a response to member's questions is getting really old. MTNMAN82 posted some good pics here, as did I: https://mbworld.org/forums/c-class-w...placement.html
Old Feb 5, 2011 | 12:54 PM
CL203
Thanks... i'll definitely give it a try...
