Desert Silver C320 Build
Intake setup for now. As of now it is aluminum flex piping and 3" plumbing rubber coupling at the maf. I will replace the tubing with aluminum pipe, i will leave the turbo for next year, but for now i will be running a 50 shot of nitrous. I have everything, just need to hook it up. The reason i had to upgrade my intake is because there wasnt a way i could put the nitrous spray nozzle
A pic that i took and edited with my galaxy s6<br/>Shot this pic right after i washed the car so thats y its really clean. Lol<br/>I got xxr 530 wheels, they should come in next week. 18x8.75 all around. +33 offset 10mm spacer up front and 20mm in the rear. I also got mororsport hardware lug studs and nuts.<br/>Anyone know if ill beable to fit 245 40 18 all around? My car has kw v1 coilovers
A little teaser of my new custom exaust and new nitrous setup. Nitrous is mostly hooked up. Just need to install aem afr gauge. Cats have been removed. I still need to remove the air pump to make some space, i may be able to flip the intake manifold aroumd that way the throttle body is up front and it will have shorter intake tubing
#32
I got in a bad car accident, and the car is totalled, so anyone who needs parts pm me, the replacement for this car is a b5 s4, so its alot funner, but next year im starting a k24 (honda engine) rwd swap in a w203 chassis, but it will be fully gutted car with a built motor
