Front Driver-side Marker Light
Just wanted to vent. Anyways, I called back today and now, the SA said that the tech didn't want to break any clips on the strips because its known to do that. The SA also said that they would charge me .5 hrs instead. Guys? Is this reasonable? What should I do?
......I also have the Euro-Strip installed....... I went to Mercedes Benz of San Diego and they were able to change the bulb for nothing or the price of it at least.....
In other words you did not install the bulb in an accessible location after your mod and you want MB to cover it under warranty. Would that be correct?
Anyways, is there a way to deprogram it from be sensed? I know that some people have ended up replacing it with some fuse. Where those mods successful?
Accessible location? I just replaced the part the where the bulb/wiring is located. It takes the same procedure to replace it. Still either have to take out the reflector or the strip.
HTH
Either way. You did a mod and the stealer is making you pay. Its your choice but I doubt you'll get very far based on what members have posted on here.
