A/C Compressor replacement for c240
Old Jun 12, 2015 | 06:28 PM
jwil24's Avatar
2004 c240 4 matic
I was wondering if anyone know the cheapest site where i can buy an a/c compressor for my c240 04 4matic and how much you think i will be charged for labor? And is it possible to drive wothout fixing it for a while or will it cause damage else where?
Old Jun 12, 2015 | 07:24 PM
02C240's Avatar
c240
http://techchoiceparts.com/inventory...-ac-compressor
The site above has one for $217.
Don't know about labor, depends where you take it and what else needs to be replaced besides the drier, evacuating/recharging the systems.
How do you know the compressor is bad?
Old Jun 13, 2015 | 06:16 PM
jwil24's Avatar
2004 c240 4 matic
It started making a rattling noise from the engine, so I took it to the mechanic he stated the compressor was no good. I need to replace the compressor and something else like a vent i think he said where air would flow through. I forgot the second part that i needed to replace also he said its about $100
Old Jun 15, 2015 | 09:35 AM
jwil24's Avatar
2004 c240 4 matic
Mechanic also stated i need an A/C reciever drive
Old Jun 17, 2015 | 08:00 PM
ooga's Avatar
02 c240
If you want to drive without doing anything to it for a while you will need re-route your belt. It is super simple to do and you can find a belt at your local autoparts store. Usually a noise is due to a bad pulley bearing. You can save yourself a lot of time and money by investigating the bearing first.
THE LESS YOU DRIVE WITHOUT RE-ROUTING YOUR BELT THE MORE YOU WILL THANK YOURSELF.
when one pulley goes it starts to take others with it.
