Sticky brakes
Old Jun 23, 2015 | 01:38 PM
Lab's Avatar
Lab
C230 kompressor
Sticky brakes
All four calipers are dragging on my Mercedes c230 kompressor coup. I replaced the Master cylinder still same thing. Anybody have any experience with this problem? Any help is appreciated thanx.
Old Jun 24, 2015 | 09:41 AM
Lab's Avatar
Lab
C230 kompressor
Yes all four calipers do not retract. Plus I just changed out the front calipers and after bleeding they don't retract. Parking brake only engages the back wheels. I'm beginning to think that all 4 flex lines are collapsed.
Old Jun 24, 2015 | 03:40 PM
Lab's Avatar
Lab
C230 kompressor
even if I crack the bleeder on the new calipers rotor does not spin freely.
Old Jun 24, 2015 | 06:05 PM
samaritrey's Avatar
Super Moderator
THE C350
If you crack the bleeder then no pressure is going to the calipers so they should not have issues.
I would replace the flex lines once you figure out whats going on it is a good practice as I assume your car is an 02-04 and has over 125k on it and you are already doing major work on the brake system.
So lets go back to the basics when were the brakes last replaced? OEM parts?
If you were to take the rebuilt calipers off how far out are they? Can you push them back in easily? What company did you get the rebuilds from?
