2002 c230K Transmission cooling lines
Old Nov 17, 2015 | 05:37 PM
jkmd's Avatar
2002 Mercedes C230 Kompressor
I have been wrestling with trying to replace the upper cooling line o ring. I seem to be unable to undo the line clip below the fitting (fat hands), so I can slide the fitting back to replace the o ring. Any tricks to slipping the line out without damaging the clip or line?
Old Nov 18, 2015 | 05:23 PM
jkmd's Avatar
Originally Posted by Plutoe
Recruit your grandson!!
That would be an option, other than both my kids have decided not to have children . I have even been hunting my nephew, but he is out of town for work. Thanks for replying.
Old Nov 19, 2015 | 07:36 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
1st off make sure you unbolt the hood support/latch and made some room to work.
Next, there's a clamp and one bolt that hold the hoses together.
Once you have that done, you'll have a little room to work, so then
should be easy.
Never really had a problem here.
