can the light sensor be removed from windshield?
thinking 3 ways,
1) remove sensor and shield from light then replace
2) jumper the wires. assuming this is just a photo diode
3) pay actual money and have dealer reprogram, no thanks, or buy some kind of kit that 'may' work.
thank you
thinking 3 ways,
thank you
At least that's my understanding of it.
Back to your original question...since your car is programmed to run with lights on all the time, I don't think the light sensor has anything to do with it, because it's the same as DRL mode for us here. You may have a ballast/bulb issue. Is it both sides flickering?
Some fyi...
