Howling noise a few seconds after starting engine
Hey Guys,
I have a C200 Kompressor (2001 model year).
A strange howling noise appears a moment ago after starting engine. It seems like it goes from the rear part of the car. An interesting observation: it's possible to stop it for a while by lifting up a window button. The sound is so strong, that I can hear it while driving.
Do you have any thoughts what it could be?
Thanks!
Thanks!
I understand that it sounds strange, but pushing the window buttons somehow makes an influence on the problem. In the moment I do it, the sound disappears and dashboard lights become a bit darker. So probably it's an electrical issue, but why it produces noise?
Super Moderator
The common cause used to be the transmission fluid pump that shuts up after a few seconds. It was redesigned. It can be a torque converter that is worn but I'm not convinced this is what you describe.
