Terrible noise
Old Jan 11, 2016 | 05:09 PM
Minoo's Avatar
Mercedes W203 2.7 CDI, 2002, Manual
Terrible noise
Hi Everyone, I have problem with my engine. Anyone have idea what is this ?
Old Jan 12, 2016 | 01:13 PM
ernieh's Avatar
W 205 c220d 2018
Faulty valve lifter; too regular to be anything else!
Ernie
Old Jan 12, 2016 | 03:34 PM
Minoo's Avatar
it's sound like valve lifter ? it's not too loud ? My car mechanic said it could be piston or bolt/pin in piston, camshaft, or "pan" ? Could it be something like that ? Sorry for my english, I hope you understand me I belive in this forum
ps. I'm not mechanic, I think valve lifter sounds more "softly". Noise in my car is "hard". Like hitting with hammer in something hard. But maybe you have right.
Old Jan 13, 2016 | 11:46 AM
jkowtko's Avatar
2005 c230SS
Sounds to me like a regular valve tap. Mine has a tap at about 1/3 that volume.
Old Jan 14, 2016 | 06:17 PM
GrandPrix's Avatar
C230 SC 2002 White 1992 Toyota Hilux 225,000 miles, 2017 Subaru STI
Almost as bad as this.
Old Jan 14, 2016 | 07:33 PM
Minoo's Avatar
Very funny...
Old Jan 14, 2016 | 08:05 PM
jkowtko's Avatar
2005 c230SS
Back to the valve tap ... here is a video that illustrates a bad crankshaft bearing and how to check for it:
I still think your noise sounds like a valve tap based on the thinness of the sound. If it was a solid knocking sound I would suspect crankshaft/rods. But I may be wrong ...
Old Jan 28, 2016 | 06:20 PM
Icebreaker's Avatar
2024 E 350
Sounds to me like a bad rod bearing. What you can do is while it is running, get a pair of plastic pliers (used just for this purpose) and pull out each plug wire one by one (put wire back after each one). If it is a rod bearing the noise will quiet down when you get to the bad bearing since now there is no compression load on the bearing.
Let me know the outcome.
