05 M.Benz C240 4Matic drivers side lower control arm bushing replacement.. need bushi
SubscribeI have a 05 M.Benz C240 4 MATIC.
The drivers side lower control arm bushing closest to the front bumper is leaking oil. Where can I find the replacement bushing for my control arm?
The control arm I have is NOT the single arm with a bushing on one side and ball joint on the other. My control arm is a large looking wishbone, 2 control bushings hook up to area near motor and one part has the ball joint on it. So picture if you could a big Y, 2 connections for large bushings and one hook up for the ball joint to hook up to steering knuckle.
With this information are there replacement bushing that will fit my control arm? No need to replace the entire large control arm as it costs $300!!
Thank you.
Thank you.
