starting issue
Old Jan 23, 2016 | 02:02 AM
sabelo's Avatar
w203 c200k elegance
starting issue
hello there well I need help with my w203 c200k elegance, I drove it previous day all was ok and the next day when I try to unlock it wont do so unless I point the key to the sensor on drivers door I got in I put the key in the ignition I turn it all the lights and warnings illuminate as normal but fuel gauge wont raise and I parked it with half tank fuel than I tried to start it the engine cranks but wont start and my service is still 7000km away and the car has less then 95k km on the clock what could be the issue please help
thank you
Old Jan 23, 2016 | 01:00 PM
LexBrett2's Avatar
2007 Mercedes E550
Have you tested your battery? That's what I would check first. Also the battery connections.
Old Jan 24, 2016 | 08:42 PM
sabelo's Avatar
w203 c200k elegance
not the battety
no it is not the battery because all other things work it cranks the engine good just the engine wont fire up and i dont understand why its fuel gauge wont raise because i parked it with half tank of fuel
Old Jan 24, 2016 | 08:50 PM
sabelo's Avatar
w203 c200k elegance
other things i noticed is it will not lock o unlock from any distance bt only when i point it to the sensor on the door and when im inside the interior light dont work fuel gauge is on strike fuel cap is locked and the towing button light wont stop flashing
Old Jan 30, 2016 | 01:49 AM
mumstoy's Avatar
2001 ML430
The battery in the key remote may be going flat thats why you have to get close or point it at the car.
Old Feb 2, 2016 | 01:29 AM
sabelo's Avatar
w203 c200k elegance
car is ok
well out of all things you could think of, as I was loading it onto a trailer I noticed water dripping from the front LHS I didn't take note I towed the car to a guy that was recommended to me by a friend I towed the car about 350km and when I got there we checked all fuses and all was ok then I recommended to check where the leak was coming from we removed the battery to find a pool of water blocked and to our surprise wiring was damaged some of the wiring was rotten the guy did his thing quick fix and the car started so now I have to buy wiring and all will be ok and I might sell the car unfortunately thank you guys hope tis will be helpful to others
Old Feb 2, 2016 | 06:15 AM
Russell Ormerod's Avatar
not a merc
Rear sam was not getting power!
