springs on C230 Coupe
Old Mar 28, 2002 | 06:05 PM
shen_q's Avatar
Cool springs on C230 Coupe
can anyone post any pics of 18' rims or higher on the C230 Coupe? If so can you indicate if you put new springs on them or not? Also can anyone recommend what kind of springs I should buy if I do decide to lower the car. Thanks!
Old Mar 28, 2002 | 06:08 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
H&R
get H&R here is a pic of my car with the H&R installed.
https://mbworld.org/forums/showthrea...2430#post42430
Old Mar 28, 2002 | 09:56 PM
onie's Avatar
2002 C-Coupe
Here's mine
http://homepage.mac.com/fsrodriguez/PhotoAlbum4.html
Old Mar 28, 2002 | 10:38 PM
Fast Cars!
spring pads
Originally posted by onie
Here's mine
your car looks great are u using the stock spring pads in the rear or did u change them, if so to what size?
Old Mar 29, 2002 | 01:18 AM
onie's Avatar
2002 C-Coupe
blackc230coupe
stock spring pads. That's why i was wondering why your cars rear wheel gap is a bit high.
Old Mar 29, 2002 | 09:25 AM
Bos's Avatar
Bos
2002 C230K
Here you go. Stock springs and shocks... for now.
Old May 24, 2002 | 04:58 AM
ting's Avatar
2002 C230K Coupe
blackcCoupe... what size spring pads do you have with your springs?
your car looks a bit high.. I want vritually no wheel gap
onie's looks very similar but even higher..
By no means is this a remark of offense... but I thought lowreing springs would take me to the point of no wheel wells.
Does changing front pads to #1 help?? the rear is close to what I want.
Old May 24, 2002 | 05:28 AM
sLaMmEd230's Avatar
2002 c230 coupe
kw makes a coilover kit for the 230....kw230 has them on his car...very nice adjustable...he has no gap at all and can still be lowered more if you want...check back in the posts to see his pic
Old May 24, 2002 | 01:29 PM
tb2's Avatar
tb2
2002 C230 Kompressor
Here is my C-Coupe with 19's on stock springs (for now).
Old May 24, 2002 | 07:28 PM
Fast Cars!
[QUOTE]Originally posted by ting
[/QUOTE
first of all i did change my rear spring pads to #1 and there is no wheel gap at all i cant even stick my fingers in there. and seconed there are no spring pads on the front to change. and lowering springs do not drop a car which is obviously what u are looking for at least no lowering spring for a mercedes thats a good brand spring will drop your car. i personally think my car is a perfect height i would not want it higher or lower at all. it seems like u might want coil overs which i think suck. but its up to u.
maybe i need to take better pics of the wheel gaps for u. but i will tell u again there is no gap in the rear at all infact its actually tucking but the front is not. on this car just the way it is if u wanted the front to tuck your front bumper will be on the floor. If u had the springs put on your car they make a HUDGE difference in person, maybe noting big in the pics though. And all the people that saw my car in person after it was done could not belive how low it was eaither. good luck
Old May 24, 2002 | 07:36 PM
Fast Cars!
ohhhhh i see why u think my car is so high since u looked at such old threads i did not have the #1 spring pads in the back in that pic heres the new ones with it installed. wait for all them to load.
https://mbworld.org/forums/showthrea...0&pagenumber=1
Old May 25, 2002 | 02:08 AM
onie's Avatar
2002 C-Coupe
New Pics
http://www.ofoto.com/BrowsePhotos.js...id=20811002303
Old May 25, 2002 | 02:14 AM
ting's Avatar
2002 C230K Coupe
Thanks for those pics
I am going to get my Coupe lowered now...
btw.. what # spring pads are you using in the back??
Old May 25, 2002 | 07:34 PM
Fast Cars!
btw.. any # spring pads are you using in the back??
i am not sure if u were talking to me but if u were i am using #1 pads in the back.
Old May 27, 2002 | 07:16 PM
ting's Avatar
2002 C230K Coupe
think #1 will be too low for my 18"??
Old May 27, 2002 | 10:56 PM
Fast Cars!
well it seems like u really wanted it to be low so probally not. i have the stock c7 tires which are low profile but with your 18's u probally have a little more of a lower profile tire with it so it will make up for the difference of my fatter tires and smaller rims VS. bigger rims and thiner tires. and if u dont want a #1 pad u can always get a 2 or 3. my car came with #4 pad but it had the C7 package but i think the non C7's might have a smaller one.
Old May 28, 2002 | 12:07 AM
ting's Avatar
2002 C230K Coupe
Hmm.. I had the Canadian equivalent of the C7 (Evolution Package), but I sold my C7's in favor of 18s... It's just that I need to purchase the SPRING PADS from MB before I bring it to my mechanic to lower it.
Is there any way of seeing what I have first?
Old May 28, 2002 | 12:26 AM
Fast Cars!
well your lucky i first lowered my car then realized they had smaller spring pads so i had to have them put on after which cost me $150.00 but since u have the evlolution package u probally have the #4 pads also but i'm not sure. u can check what u have i did the same thing u just have to go look under the back of the car just kinda slide under it lol make sure the cares off and just look at the rear spring and look on top of them for a rubber pad u will find out which pad u have by counting the small rubber nipples on them very small if u have a #4 pad u will see 4 small dots and i guess u get the idea. just look careful for them and u will see them there like a.most a pen dot size but u will see them just look careful.
goodluck
