Alternatorn Battery SRS ESP
MB C180 w203. -04
MB 2004 Comp. W203. This is a Google translation.
I've changed the alternator and battery.
-The battery in the rest 13,4V.
-at start 12.5V.
- shortly after> 18V. On Disply red Alternator,Battery problem.
- Idle 13.4V.
-1500rpm 14.3V.
-After 3 ... 4 minutes remain> 18V at any second.
- Since there seems to come more.
During all the time warned of the brake lights do not work. Both right and left. other codes: ESP, SRS, and BAS have occurred.
some suggestions to the problem?
it may be the alternator is wrong even if it is new?
-at start 12.5V.
- Idle 13.4V.
-1500rpm 14.3V.
Moderator Alumni
I'm also interested in what is going on here as I've had something similar to this occur once or twice.
I couldn't imagine that the esp/abs, srs, brake lights, and alternator/battery warnings are directly related unless a CAN-BUS or the front SAM are malfunctioning. But I am unsure of how exactly to test the health of either of those units.
In my case, I also had a "display faulty - visit workshop" message.
Nilserikp: Did this occur in extreme rain or very hot weather?
MB C180 w203. -04
at the first opportunity (before replacing the alternator), it was like that 25 degrees.
also had problems with the roof, windows.
Back in Sweden, I have made a YouTube film as showing the problem. there is interest I can give the link.
Google translate.
Google translate.
Sounds like you voltage regulator is no god. esp/abs could just need reset from the battery being disconnected.
