Aux harness installation OEM part vs 12 pin
Old Jun 19, 2016 | 12:19 AM
Marat Galeyev's Avatar
Mercedes c230 w203
Hello,
I have 2006 c230 w203 and I'd like to install aux cable. I've read several threads and found that most people order an OEM 2104405005 part, however there is also a 12 pin aux adapter, like this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1, which is also said to be compatible. I do understand installation procedure for an OEM part, just wondering have anyone had an experience installing a 12 pin one? Does it go directly to multimedia unit?
Old Jun 19, 2016 | 03:00 PM
LexBrett2's Avatar
2007 Mercedes E550
Originally Posted by Marat Galeyev
Hello,
The part you are referring to goes into a plug just under the trim on passenger side. There are several great DIYs.
Even better, you can make it totally wireless with a Bluetooth dongle!
http://m.ebay.com/itm/3-5mm-AUX-Car-Bluetooth-Receiver-Speaker-Music-Streaming-Receiver-Adapter-/331864426942?_trkparms=pageci%3D2a01b177-e147-4ce5-87ae-827794e88061%2Cparentrq%3D6a06d76f1550abc1f4be1492 ffff2eb1%2Ciid%3D1%2Cobjectid%3D44999
Old Jun 19, 2016 | 04:09 PM
Mercedes c230 w203
Are you referring to 4 pin adapter installation, like this:
? can you point where does the 12 pin adapter go, which trim on passenger side?
Old Jun 19, 2016 | 04:26 PM
LexBrett2's Avatar
2007 Mercedes E550
Are you referring to 4 pin adapter installation, like this: How to install aux in c230 kompressor c class - YouTube ? can you point where does the 12 pin adapter go, which trim on passenger side?
I believe the 12 pin adapter actually goes behind the radio head unit, which is a nightmare to remove. I'd stick to the 4 pin adapter in the video.
Old Jun 19, 2016 | 05:53 PM
Mercedes c230 w203
Thanks, yes that's what I'm thinking as well.
I was just wondering why those 12pin aux adapters are so popular and says it compatible with w203, I honestly haven't found any DIY on the web on it.
Old Jun 19, 2016 | 09:34 PM
LexBrett2's Avatar
2007 Mercedes E550
Maybe because the 12 pin goes into radio head unit and gives the appearance of a clean oem install. But the horrible experience of taking apart the dash. Plus the 4 pin is a clean install too, and there is even a precut hole in the glove box for the female plug!
Old Jun 22, 2016 | 03:51 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
BTW, in the 2006 cars there may not be a harness under the kick panel, if I remember correctly it's a hit or miss. Might want to check if it's there and then decide which wire to buy.
