AC not working, temp sensor?
Old Jul 2, 2016 | 02:19 AM
blackberg's Avatar
2005 C55 AMG; 2000 CLK320 Cabriolet, 2000 C230 Kompressor & 2001 ML430
This is for 05 c55amg
system is full, checked by mechanic today.
replaced the AC pressure switch (2038211592) at the condensor
the Compressor and all components are a year old.
Star diagnostics shows that the car is sending the signal to the compressor, and a meter shows that cable has a signal, but its not getting cold.
Gauges on the system do not show the high side increasing when the AC compressor is supposed to be on.
What I did find is that the ambient temperature sensor is damaged and not sending a signal all the time.
STAR showed a temperature sensor at 0°, its probably that sensor?
Will the broken ambient temperature sensor cause the AC to not turn on?
thanks
-bb
