Removal of Steering Wheel
Old Mar 11, 2004 | 02:54 AM
ggong5150's Avatar
03 C320 (For Sale), 08 Audi TT
Hoping you guys can help I searched for instructions on removing the wheel and no such luck. Is there any problems with the airbag or the computer? Could it be done without having to go to the dealer?
Old Mar 11, 2004 | 03:44 AM
awiner's Avatar
2003 CL55 AMG
Check the CL55 forum. I explained how to do it there a few weeks ago.
Old Mar 11, 2004 | 04:02 AM
ggong5150's Avatar
would you mine e-mailing me info. thanks
Old Mar 11, 2004 | 12:43 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Its EASY! 10Min MAX!
The Tools required are a Long Torx ..Mercedes sells the Socket to remove the air bag.Then a Allen Socket to remove the Steering wheel.
Do NOT Have or turn the Key on While doing this!
Old Mar 11, 2004 | 01:11 PM
SUNILP's Avatar
2015 E250D
get a 10mm Hex socket and a torx 30 screwdriver. Look behind the steering wheel adn you will see 2 torx 30 screws. Unscrew these and the front airbacg assy comes out. Then use the 10mm hex and unscrew the steering wheel. That's it.
Old Mar 11, 2004 | 10:00 PM
ggong5150's Avatar
thanks guys for the info!
Old Mar 12, 2004 | 05:10 AM
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
A word of caution tho ... the center 10mm hex is a biaattcchh to remove the first time around ... mine was so tight I had to ask my friend to hold the steering wheel...
