AC Off vs EC Rest?
Does this mean that my vehicle has no residual heating option when the engine is off?
Also how long does it take for your vehicle to reach over 80 degree engine heat on a 17-20degree weather?
I think mine either has a thermostat problem or something else is wrong coz it takes some driving to reach around 75degree.
Many thanks
When the engine is running, pushing EC/Rest turns off the AC compressor, EConomy mode is on and the top LED turns on.
When the engine is turned off, pushing the same EC/Rest button turns on residual heating and the bottom LED lights up.
My W203 heats up in minutes in winter time, so if yours takes a long time (please define "long") then you may have a thermostat leak or failure.
Regarding your coolant temp question----you have an issue,replace the thermostat!!
I didnt know that it requires an additional pump for the "Rest" but now i know mine does not have it.
Thanks man
Mine went to 180F in just 5 minutes of driving this morning (mid 60's outside temp), so you may very well have a thermostat that is stuck open.
In regards to the Rest function, that doesn't use a circulation pump, it just takes advantage of the fact that the coolant in the system is hot and it will turn on the heater fan at low speed to transfer some of that heat into the car. As coolant cools off during this process it will circulate within the system due to convection.
HVAC CONTROL is built date dependent. It may work, and you just relearn how to use A/C. And it may not work. Ensure you normalize the flaps holding front defrost and recirculate.
STF. Especially for those of use that did the digital swap.
