Alternator and some issue
I happy to join this forum, My car is c200K 2003 engine 2710940 ( Eaton supper charge) , I am facing with some problem as below, please give me an advice .
1. Alternator warning lamp On when engine run ( Battery is charging OK with 14.5vdc, feedback voltage wire from the regulator voltage IC is 13.5 ,, wire is continue to ECU), I tried clear error by ODB tool but problem was not change, I tried also replace other IC it taken from c180k Sam engine code
2. Eaton supercharge has noise during running , who may help me how to fix? I remove but not found any abnormal.
3. Idle rpm engine drop quickly and up again when AC turn on or ship gear to D
I hope some expert can support me how to fix it. .
Thank you very much all my Team
