m271 Belt tensioner replacement
Old Jun 20, 2023 | 11:13 AM
Akluin's Avatar
w203 c180k 2003
Originally Posted by slammer111
Hi, this thread will probably help you.
Personally I find the tensioner doesn't really go bad. If you think about it, it's just a torsion spring. I found nothing wrong with mine when I had the supercharger out. Still rolling on the original one. The pulley itself can be replaced separately, but personally I found mine was fine too.
Mine is wobbling, and i need to check the breather hose and change the engine mount, i get the link to the steering column removal and I will try that this weekend, thanks
