C230K Stalling????
Old Mar 21, 2004 | 03:03 PM
Langlois's Avatar
C230K Stalling????
All, I having a problem with my C230K it will stall for no apparent reason (any speed, any weather, no pattern) Has anyone here had this problem??
Old Mar 21, 2004 | 04:58 PM
fstrd1's Avatar
I had that problem with my c240, I had to change out four different batteries and finally the mb service center found out that the problem was a internal short coming from the instrument cluster. After they replaced the instrument cluster I never had any more problems.
Good Luck!
Glen
Old Mar 23, 2004 | 12:36 AM
Sponger's Avatar
Mine used to sputter after start up every so often. The dealer installed new software and haven't had a problem since.
Old Mar 25, 2004 | 12:36 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
Mine used to hesistate when in reverse gear and backing up at low speeds, dealer updated the ECU software and raised idle from 650rpm to 670rpm. Now it is much smoother, but it did stall for no reason one time when I was backing out of a parking spot.
It hasn't done it again since, but it's only been a week. If it stalls again, I will bring it back to the dealer.
