Obd-2
Old Mar 23, 2004 | 07:11 AM
rubensans's Avatar
Brabus K3
Obd-2
I just received the OBD-2 from Alex C. Peper.
I can't connect to my W203CL.
Which special conf parametres do I have to put?
I have set the port speed to 19200.
Here is the log:
Tue 23 Mar 2004 ve109
11:19:59.8 - initializing serial port
11:19:59.9 - connected rs232 port 2
11:19:59.9 - initializing vehicle using indo router
11:20:00.0 - Log In #1 SAE J1850 PWM @ 120
11:20:00.2 - route v4F.07
11:20:00.4 - route v4F.07
11:20:00.7 - route v4F.07
11:20:00.8 - timeout 3 mode= $01
11:20:00.8 - no response
11:20:00.8 - Log In #1 SAE J1850 VPW @ 120
11:20:01.0 - route v4F.07
11:20:01.2 - route v4F.07
11:20:01.5 - route v4F.07
11:20:01.6 - timeout 3 mode= $01
11:20:01.6 - no response
11:20:02.6 - Login #1 ISO 9141-2 @ 120 10 25
11:20:02.6 - Login #1 ISO/DIS KWP2000-4 slow @ 120 10 25
11:20:06.6 - no response
11:20:06.6 - Login #1 ISO/DIS KWP2000-4 fast @ 120 10 25
11:20:07.6 - no response ping loop back
11:20:08.5 - no response ping loop back
11:20:09.3 - no response ping loop back
11:20:09.3 - timeout 3 mode= $81
11:20:12.3 - Log In #2 SAE J1850 PWM @ 120
11:20:14.8 - timeout 3 mode= $01
11:20:14.8 - no response
11:20:14.8 - Log In #2 SAE J1850 VPW @ 120
11:20:17.8 - timeout 3 mode= $01
11:20:17.8 - no response
11:20:18.8 - Login #2 ISO 9141-2 @ 120 10 25
11:20:18.8 - Login #2 ISO/DIS KWP2000-4 slow @ 120 10 25
11:20:24.0 - no response
11:20:25.0 - Login #2 ISO/DIS KWP2000-4 fast @ 120 10 25
11:20:27.1 - no response ping loop back
11:20:28.4 - no response ping loop back
11:20:29.0 - no response ping loop back
11:20:29.1 - timeout 3 mode= $81
11:20:29.1 - no response
11:20:31.7 - Log In #3 SAE J1850 PWM @ 120
11:20:33.5 - timeout 3 mode= $01
11:20:33.5 - no response
11:20:33.5 - Log In #3 SAE J1850 VPW @ 120
11:20:33.8 - terminated scan
11:20:38.6 - saved 0 messages 2 KB to :
C:\CAR-CODE\3
manufacturer files:
Core
Not Defined
none
Old Mar 23, 2004 | 09:04 AM
SilverStar's Avatar
02' Silver C230 Sport Coupe
WTF
Old Mar 23, 2004 | 09:08 AM
rubensans's Avatar
Brabus K3
wtf?
Old Mar 23, 2004 | 10:25 AM
Buellwinkle's Avatar
wtf = "what the f*ck", don't know if it applies to your question though. You'll have to excuse Silverstar, ever since they closed the huge mental institution in Camarillo it's been hard on them. It recently became a university but most people can't tell the difference.
I have the same software and all I do it plug it in, boot the laptop, run the software, turn the ignition on (very important) and go to the screen that collects data and press send, it goes out and connects after a few seconds. If you still have trouble it could be the comm port setting for the cable. If that doesn't work call Alex.
Old Mar 23, 2004 | 03:14 PM
rubensans's Avatar
Brabus K3
more logs
19:51:21.0 - initializing serial port
19:51:21.0 - connected rs232 port 2
19:51:21.1 - initializing vehicle using indo router
19:51:21.1 - Login #1 ISO 9141-2 @ 120 10 25
19:51:21.1 - Login #1 ISO/DIS KWP2000-4 slow @ 120 10 25
19:51:21.1 - Login #1 ISO/DIS KWP2000-4 fast @ 120 10 25
19:51:21.1 - sent prio=3 func IFR0 legislated src=F1 1.0
19:51:23.9 - no response
19:51:24.1 - sent prio=3 func IFR0 legislated src=F1 1.0
19:51:26.6 - no response
19:51:26.7 - sent prio=3 func IFR0 legislated src=F1 1.0
19:51:29.0 - no response
19:51:29.2 - timeout 3 mode= $01
19:51:29.2 - no response
19:51:29.2 - sent prio=6 func IFR1 src=F1 1.0
19:51:32.3 - no response
19:51:32.4 - sent prio=6 func IFR1 src=F1 1.0
19:51:35.5 - no response
19:51:35.8 - sent prio=6 func IFR1 src=F1 1.0
19:51:39.2 - no response
19:51:39.3 - timeout 3 mode= $01
19:51:39.3 - no response
19:51:39.3 - sent prio=6 func IFR1 src=F1 129
19:51:40.3 - recv prio=4 func IFR1 src=01 129
19:51:40.3 - no response
19:51:40.3 - Login #1 ISO 9141-2 @ 120 10 25
19:51:40.3 - Login #1 ISO/DIS KWP2000-4 slow @ 120 10 25
19:51:40.3 - Login #1 ISO/DIS KWP2000-4 fast @ 120 10 25
19:51:40.3 - sent prio=3 func IFR0 legislated src=F1 1.0
19:51:42.6 - no response
19:51:42.7 - sent prio=3 func IFR0 legislated src=F1 1.0
19:51:45.0 - no response
19:51:45.1 - sent prio=3 func IFR0 legislated src=F1 1.0
19:51:48.2 - no response
19:51:48.3 - timeout 3 mode= $01
19:51:48.3 - no response
19:51:48.3 - sent prio=6 func IFR1 src=F1 1.0
19:51:51.4 - no response
19:51:51.5 - sent prio=6 func IFR1 src=F1 1.0
19:51:54.6 - no response
19:51:54.8 - sent prio=6 func IFR1 src=F1 1.0
19:51:59.1 - no response
19:51:59.3 - timeout 3 mode= $01
19:51:59.3 - no response
19:51:59.3 - sent prio=6 func IFR1 src=F1 129
19:51:59.9 - no response
19:51:59.9 - route v4F.0C
19:52:00.0 - sent prio=6 func IFR1 src=F1 129
19:52:00.6 - no response
19:52:00.6 - route v4F.0C
19:52:00.7 - sent prio=6 func IFR1 src=F1 129
19:52:01.3 - no response
19:52:01.3 - route v4F.0C
19:52:01.5 - timeout 3 mode= $81
19:52:01.5 - no response
19:52:03.8 - Login #2 ISO 9141-2 @ 120 10 25
19:52:03.8 - Login #2 ISO/DIS KWP2000-4 slow @ 120 10 25
19:52:03.8 - Login #2 ISO/DIS KWP2000-4 fast @ 120 10 25
19:52:03.8 - sent prio=3 func IFR0 legislated src=F1 1.0
19:52:06.9 - no response
19:52:07.0 - sent prio=3 func IFR0 legislated src=F1 1.0
19:52:09.4 - no response
19:52:09.5 - sent prio=3 func IFR0 legislated src=F1 1.0
19:52:11.8 - no response
19:52:11.9 - timeout 3 mode= $01
19:52:11.9 - no response
19:52:11.9 - sent prio=6 func IFR1 src=F1 1.0
19:52:15.5 - no response
19:52:15.5 - sent prio=6 func IFR1 src=F1 1.0
19:52:18.6 - no response
19:52:18.8 - sent prio=6 func IFR1 src=F1 1.0
19:52:22.3 - no response
19:52:22.4 - timeout 3 mode= $01
19:52:22.4 - no response
19:52:22.4 - sent prio=6 func IFR1 src=F1 129
19:52:23.0 - no response
19:52:23.0 - route v4F.0C
19:52:23.1 - sent prio=6 func IFR1 src=F1 129
19:52:23.9 - no response
19:52:23.9 - route v4F.0C
19:52:23.9 - sent prio=6 func IFR1 src=F1 129
19:52:25.4 - no response
19:52:25.4 - route v4F.0C
19:52:25.5 - timeout 3 mode= $81
19:52:25.5 - no response
19:52:25.5 - Login #2 ISO 9141-2 @ 120 10 25
19:52:25.5 - Login #2 ISO/DIS KWP2000-4 slow @ 120 10 25
19:52:25.5 - Login #2 ISO/DIS KWP2000-4 fast @ 120 10 25
19:52:25.5 - sent prio=3 func IFR0 legislated src=F1 1.0
19:52:31.3 - no response
19:52:31.4 - sent prio=3 func IFR0 legislated src=F1 1.0
19:52:33.8 - no response
19:52:34.2 - sent prio=3 func IFR0 legislated src=F1 1.0
19:52:36.5 - no response
19:52:36.6 - timeout 3 mode= $01
19:52:36.6 - no response
19:52:36.6 - sent prio=6 func IFR1 src=F1 1.0
19:52:40.5 - no response
19:52:40.5 - sent prio=6 func IFR1 src=F1 1.0
19:52:43.7 - no response
19:52:43.7 - sent prio=6 func IFR1 src=F1 1.0
19:52:46.9 - no response
19:52:47.0 - timeout 3 mode= $01
19:52:47.0 - no response
19:52:47.0 - sent prio=6 func IFR1 src=F1 129
19:52:47.6 - no response
19:52:47.6 - route v4F.0C
19:52:47.8 - sent prio=6 func IFR1 src=F1 129
19:52:48.4 - no response
19:52:48.4 - route v4F.0C
19:52:48.5 - sent prio=6 func IFR1 src=F1 129
19:52:49.1 - no response
19:52:49.1 - route v4F.0C
19:52:49.2 - timeout 3 mode= $81
19:52:49.2 - no response
19:52:52.3 - Login #3 ISO 9141-2 @ 120 10 25
19:52:52.3 - Login #3 ISO/DIS KWP2000-4 slow @ 120 10 25
19:52:52.3 - Login #3 ISO/DIS KWP2000-4 fast @ 120 10 25
19:52:52.3 - sent prio=3 func IFR0 legislated src=F1 1.0
19:52:54.6 - no response
19:52:54.7 - sent prio=3 func IFR0 legislated src=F1 1.0
19:52:54.8 - terminated scan
19:53:01.6 - saved 1 messages 2 KB to :
C:\CAR-CODE\5
manufacturer files:
Core
Not Defined
none
Old Mar 23, 2004 | 03:15 PM
rubensans's Avatar
Brabus K3
and more
19:56:17.2 - initializing serial port
19:56:17.2 - connected rs232 port 2
19:56:17.2 - initializing vehicle using indo router
19:56:17.3 - Log In #1 SAE J1850 PWM @ 120
19:56:17.3 - sent prio=3 func IFR1 legislated src=F1 1.0
19:56:17.4 - no response
19:56:17.4 - route v4F.07
19:56:17.5 - sent prio=3 func IFR1 legislated src=F1 1.0
19:56:17.7 - no response
19:56:17.7 - route v4F.07
19:56:17.8 - sent prio=3 func IFR1 legislated src=F1 1.0
19:56:18.0 - no response
19:56:18.0 - route v4F.07
19:56:18.0 - timeout 3 mode= $01
19:56:18.1 - no response
19:56:18.1 - Log In #1 SAE J1850 VPW @ 120
19:56:18.1 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:18.2 - no response
19:56:18.2 - route v4F.07
19:56:18.3 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:18.5 - no response
19:56:18.5 - route v4F.07
19:56:18.6 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:18.7 - no response
19:56:18.7 - route v4F.07
19:56:18.8 - timeout 3 mode= $01
19:56:18.8 - no response
19:56:18.8 - Login #1 ISO 9141-2 @ 120 10 25
19:56:18.8 - Login #1 ISO/DIS KWP2000-4 slow @ 120 10 25
19:56:18.8 - Login #1 ISO/DIS KWP2000-4 fast @ 120 10 25
19:56:18.8 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:21.1 - no response
19:56:21.3 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:23.6 - no response
19:56:23.7 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:26.0 - no response
19:56:26.1 - timeout 3 mode= $01
19:56:26.1 - no response
19:56:26.1 - sent prio=6 func IFR1 src=F1 1.0
19:56:29.3 - no response
19:56:29.4 - sent prio=6 func IFR1 src=F1 1.0
19:56:32.5 - no response
19:56:32.6 - sent prio=6 func IFR1 src=F1 1.0
19:56:35.8 - no response
19:56:35.8 - timeout 3 mode= $01
19:56:35.8 - sent prio=6 func IFR1 src=F1 129
19:56:36.5 - recv prio=4 func IFR1 src=01 129
19:56:36.5 - no response
19:56:36.5 - Login #1 ISO 9141-2 @ 120 10 25
19:56:36.5 - Login #1 ISO/DIS KWP2000-4 slow @ 120 10 25
19:56:36.5 - Login #1 ISO/DIS KWP2000-4 fast @ 120 10 25
19:56:36.5 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:38.9 - no response
19:56:39.0 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:41.3 - no response
19:56:41.4 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:43.7 - no response
19:56:43.8 - timeout 3 mode= $01
19:56:43.8 - no response
19:56:43.8 - sent prio=6 func IFR1 src=F1 1.0
19:56:47.0 - no response
19:56:47.1 - sent prio=6 func IFR1 src=F1 1.0
19:56:50.2 - no response
19:56:50.3 - sent prio=6 func IFR1 src=F1 1.0
19:56:53.4 - no response
19:56:53.5 - timeout 3 mode= $01
19:56:53.5 - no response
19:56:53.5 - sent prio=6 func IFR1 src=F1 129
19:56:54.2 - no response
19:56:54.2 - route v4F.0C
19:56:54.3 - sent prio=6 func IFR1 src=F1 129
19:56:54.9 - no response
19:56:54.9 - route v4F.0C
19:56:55.0 - sent prio=6 func IFR1 src=F1 129
19:56:55.7 - no response
19:56:55.7 - route v4F.0C
19:56:55.8 - timeout 3 mode= $81
19:56:55.8 - no response
19:56:57.8 - Log In #2 SAE J1850 PWM @ 120
19:56:57.8 - sent prio=3 func IFR1 legislated src=F1 1.0
19:56:57.9 - no response
19:56:57.9 - route v4F.07
19:56:58.1 - sent prio=3 func IFR1 legislated src=F1 1.0
19:56:58.2 - no response
19:56:58.2 - route v4F.07
19:56:58.3 - sent prio=3 func IFR1 legislated src=F1 1.0
19:56:58.5 - no response
19:56:58.5 - route v4F.07
19:56:58.5 - timeout 3 mode= $01
19:56:58.5 - Log In #2 SAE J1850 VPW @ 120
19:56:58.5 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:58.7 - no response
19:56:58.7 - route v4F.07
19:56:58.8 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:59.0 - no response
19:56:59.0 - route v4F.07
19:56:59.1 - sent prio=3 func IFR0 legislated src=F1 1.0
19:56:59.3 - no response
19:56:59.3 - route v4F.07
19:56:59.3 - timeout 3 mode= $01
19:56:59.3 - Login #2 ISO 9141-2 @ 120 10 25
19:56:59.3 - Login #2 ISO/DIS KWP2000-4 slow @ 120 10 25
19:56:59.3 - Login #2 ISO/DIS KWP2000-4 fast @ 120 10 25
19:56:59.3 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:01.7 - no response
19:57:01.8 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:04.1 - no response
19:57:04.2 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:06.6 - no response
19:57:06.7 - timeout 3 mode= $01
19:57:06.7 - no response
19:57:06.7 - sent prio=6 func IFR1 src=F1 1.0
19:57:09.8 - no response
19:57:09.9 - sent prio=6 func IFR1 src=F1 1.0
19:57:13.0 - no response
19:57:13.1 - sent prio=6 func IFR1 src=F1 1.0
19:57:16.3 - no response
19:57:16.3 - timeout 3 mode= $01
19:57:16.3 - sent prio=6 func IFR1 src=F1 129
19:57:17.0 - no response
19:57:17.0 - route v4F.0C
19:57:17.1 - sent prio=6 func IFR1 src=F1 129
19:57:17.8 - no response
19:57:17.8 - route v4F.0C
19:57:17.8 - sent prio=6 func IFR1 src=F1 129
19:57:18.5 - no response
19:57:18.5 - route v4F.0C
19:57:18.6 - timeout 3 mode= $81
19:57:18.6 - no response
19:57:18.6 - Login #2 ISO 9141-2 @ 120 10 25
19:57:18.6 - Login #2 ISO/DIS KWP2000-4 slow @ 120 10 25
19:57:18.6 - Login #2 ISO/DIS KWP2000-4 fast @ 120 10 25
19:57:18.6 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:21.0 - no response
19:57:21.0 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:23.4 - no response
19:57:23.5 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:25.8 - no response
19:57:25.9 - timeout 3 mode= $01
19:57:25.9 - no response
19:57:25.9 - sent prio=6 func IFR1 src=F1 1.0
19:57:29.0 - no response
19:57:29.1 - sent prio=6 func IFR1 src=F1 1.0
19:57:32.3 - no response
19:57:32.4 - sent prio=6 func IFR1 src=F1 1.0
19:57:35.5 - no response
19:57:35.6 - timeout 3 mode= $01
19:57:35.6 - no response
19:57:35.6 - sent prio=6 func IFR1 src=F1 129
19:57:36.3 - no response
19:57:36.3 - route v4F.0C
19:57:36.3 - sent prio=6 func IFR1 src=F1 129
19:57:37.0 - no response
19:57:37.0 - route v4F.0C
19:57:37.1 - sent prio=6 func IFR1 src=F1 129
19:57:37.8 - no response
19:57:37.8 - route v4F.0C
19:57:37.9 - timeout 3 mode= $81
19:57:37.9 - no response
19:57:39.9 - Log In #3 SAE J1850 PWM @ 120
19:57:39.9 - sent prio=3 func IFR1 legislated src=F1 1.0
19:57:40.0 - no response
19:57:40.0 - route v4F.07
19:57:40.1 - sent prio=3 func IFR1 legislated src=F1 1.0
19:57:40.3 - no response
19:57:40.3 - route v4F.07
19:57:40.4 - sent prio=3 func IFR1 legislated src=F1 1.0
19:57:40.5 - no response
19:57:40.5 - route v4F.07
19:57:40.6 - timeout 3 mode= $01
19:57:40.6 - no response
19:57:40.6 - Log In #3 SAE J1850 VPW @ 120
19:57:40.6 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:40.8 - no response
19:57:40.8 - route v4F.07
19:57:40.9 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:41.1 - no response
19:57:41.1 - route v4F.07
19:57:41.2 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:41.3 - no response
19:57:41.3 - route v4F.07
19:57:41.4 - timeout 3 mode= $01
19:57:41.4 - no response
19:57:41.4 - Login #3 ISO 9141-2 @ 120 10 25
19:57:41.4 - Login #3 ISO/DIS KWP2000-4 slow @ 120 10 25
19:57:41.4 - Login #3 ISO/DIS KWP2000-4 fast @ 120 10 25
19:57:41.4 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:43.8 - no response
19:57:43.9 - sent prio=3 func IFR0 legislated src=F1 1.0
19:57:44.1 - terminated scan
19:57:50.1 - saved 1 messages 2 KB to :
C:\CAR-CODE\6
manufacturer files:
Core
D-Chry
none
Old Mar 23, 2004 | 03:16 PM
rubensans's Avatar
Brabus K3
Definitly I will send a mail to Alex
Old Mar 23, 2004 | 03:34 PM
SilverStar's Avatar
um....WTF?....where's my mommy?...why is there a twinky in my ***?
Old Mar 23, 2004 | 09:04 PM
rrf's Avatar
rrf
ISO/DIS KWP2000-4 FAST @ 65 10 20
I use the Alex Pepper cable and software, it works great.
Mine connects on:
Blue Router
"route F3" ......which is probably RS232 >=56000baud
sometimes it is
ISO/DIS KWP2000-4 FAST @ 75 10 20
[ I guess your serial port is configured incorrectly on your laptop ]
Old Mar 24, 2004 | 01:53 AM
rubensans's Avatar
Brabus K3
I will try the 56000 in serial; before I had 19200.
I also will put the
Thanks.
Old Mar 25, 2004 | 02:51 AM
rubensans's Avatar
Brabus K3
Can someone send me a "print screen" of the 3 folders in gateway to rubensans@rubensans.com?
Best Regards,
Ruben.
The windows serial port should be configured at 56000bps, no?
Old Mar 25, 2004 | 10:13 AM
I don't understand why you are playing with the options. As long as the ignition is on, everything is plugged in and you select the correct com port it will scan for all the right protocol. Have you veryified -
- com port works
- the correct com port setting is chosen in the software
- you don't have anything that may conflict with it like Palm Hotsync, IR com port, modem, etc...
- the ignition is on - start the car if you don't understand
- the cables are fully seated
- Spanish cars comply with OBD-2 standards (this is a U.S. thing).
Old Mar 25, 2004 | 03:34 PM
rubensans's Avatar
Brabus K3
- com port works
YES.
YES.
NO.
YES
YES.
DON'T KNOW.
