KLEEMANN Alloy pulley dyno- RPM axis
BT
Brad
If it does as some implied then there may not be as much a difference between the two pulley types as the graph implies.
Also, the car supposedly had nothing on it to enhance performance other than the pulley kit but I've seen in another post that Kleemann has an aftermarket muffler. Was this muffler on for all three test or none at all?
btw - Klemmann is with 2 "n"s, not one as in Kleeman. Common mistake, but Brandon puts a lot of effort into our board and I think we owe him the respect to spell it correctly!
Brad
Actually it's the other way arround.
Right after a boost kit is fitted, the car will have more power than
after a few houndred miles.
The car will run smother when the ECU breaks in, in the middle of the rpm range, but will loose 10 - 15 on the top.
So the figures KLEEMANN shows are right.
How can you possibly have more questions on such a simple tuning :p :p :p
It's just that one would think that with the extra pressure and heat and changes in fuel/air mixture that the ECU would have to make adjustments to it's ignition curve and fuel delivery. At first the pre-detination detector would cause the timing to retard and cut back on power or a too lean condition may cause increases in head temperatures that the computer reacts to immediately by cuting back on power to protect itself. Once the ECU learned that this is normal over time it would fine tune itself. The question is if the fine tuning would reduce power or make more power. Since I did not write the program that MB uses in their ECU it's all speculation though.
It would be interesting to do a dyno right after and then wait a few days or weeks and redo the dyno just for the curiosities sake and nothing else. Probably someone from GIAC or Upsolute understands this more. I know they are on the forum so if you read this please let us know what goes on in my car's little brain. My brain is toast so there's no sense going there.
