Transmission Flush on 05 C230 with 248,000 Miles
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
I'm just expressing an opinion.
To each his own. I looked up the specs on both products, and while similar they are not identical.
Interestingly they stayed in the specification that they cannot say that their product is compatible with all the vehicles they list in the state of California If it does not match the specs.
So I wonder if I go look at a bottle and a store here will it say it's still okay for Mercedes? I don't know I don't care because I won't need to do my transmission again for another 20,000 miles and I have at least four quarts on hand already so doesn't matter to me.
Geez, just do it the right way. All those miles and too cheap and lazy to change the filter.
and use the shell ATF 134. That maxlife Valvoline crap is not approved by Mercedes. The shell product is cheap enough. Less than a hundred bucks a case on Ebay if you're going to do a full flush. Here's a kit that has everything you could want or need for changing your transmission fluid minus the fluid.
https://www.ebay.com/itm/OEM-Mercedes-722-6-5-Speed-Transmission-Service-Kit-COMPLETE-w-Dipstick-DELUXE-/322427014483
Or since you guys don't believe the filters are worth a damn and the non genuine stuff is the same as the genuine stuff then go for this one.
https://www.ebay.com/itm/Mercedes-722-6-5-Speed-Transmission-Service-Kit-COMPLETE-with-Dipstick-DELUXE-/222592443750
Here's some info that might be of use to you.
https://mbworld.org/forums/c-class-w...n-related.html
Shell website says so here - but curious if any issues you've experienced with the Shell stuff vs MB OEM fluid? Its definitely cheaper...
http://shop.sclubricants.com/shell-atf-134
Shell ATF 134 has been developed as an initial-fill and service-fill fluid for mercedes-Benz 7-speed automatic transmissions.
Shell ATF 134 is mandatory for NAG2V Sport transmissions with wet starting clutch and the 7G-Tronic (model 722.9/W7A700/NAG2). It can also be used in all 5-speed transmissions with controlled torque converter lockup clutch for vehicles with rear-wheel drive (model 722.6/W5A 580/NAG1).
Performance, Features & Benefits
Shell ATF 134 is a high performance ATF formulated with hydrocrack synthetic basic oils, combined with premium quality latest technology performance additives.
Specifications, Approvals & Recommendations
- MB-Approval 236.14
In NZ I rang the service dept of MB & they told me after 100,000kms one should change the oil in the auto box. A dipstick may be good to look at but not the bottom? There reasoning is once a car gets to this km stage things start to happen & it doesn't hurt to change the oils. An MD service they do it. In fact we have to get a yearly [WOF] Warrant of fitness. Inspectors will also check all your oils & brake fluid--any discolouration in the fluid you fail but have 21 days to return to get the WOF sticker on your car so it doesn't hurt to change!!!
jvakos (12-11-2018)
I've used MB genuine fluid twice and Shell ATF 134 twice.
Currently running the ATF134 at 245K miles, and transmission is great, no slippages nothing.
For fluids on any mercedes vehicle, check here...
https://bevo.mercedes-benz.com/bevol...ets-sort1.html
I'm not goung to use non approved products to save $20 once every 5 years or some shiet.
C230SC - hey just to confirm, the Shell 134 ATF is OK for our 722.6 transmissions and on par with the MB OEM stuff?
Pretty sure I read somewhere, that Mercedes came up with the fluid in assocation with Shell, so likely stuff in Mercedes bottle is from Shell, but can't say for certain. Good luck!
#32
After that, i proceeded to use a mityvac with long 1/4 inch hose inserted into the trans dipstick location under the hood to suck out 3 quartz at a time then refill with 3 quartz new Shell atf 134. While not a professional full flush, I did this this process 3 times (9 quartz new fluid flushed through) and it worked great with each time the fluid becoming less brown/dirty and significantly more red. The fluid isn’t not clear red, but quite good and the trans shifts AMAZINGLY now smooth as butter and no jerking or clunking!!!!!
Did all this for under 200 bucks of which the vac was $80 the 12 quartz of fluid off eBay was $90 and I still have some left to flush and pump out over the next few months. All in all - trans is happy and shifting like new and I didn’t have to pay the dealer 600 for a full flush!!!
Thanks again C230sport and tjts1 for the help fellas
