How to adjust the subwoofer on W203 station
The sub has its own power amp which is adjusted (x-over frequency and level) very poorly so I thought I was going to tweak the knobs... except there are no knobs to be seen...
A sub that is wired into the full range signal of the rear speakers has a x-over filter somewhere.
Anyone has experience with this? Must I really remove the entire amp to reach the adjustment knobs? Or are they hidden away somewhere where you can just feel your way around the amp and tweak away?
Or am I totally wrong and does it run on a separate subwoofer send from the radio?
Thank you so much for any info on this!
