Help - Dropped tool behind radiator and cant get it out
Old May 1, 2017 | 01:24 PM
12steps's Avatar
w203 c200
Arrrgh, I managed to drop a set of vicegrips between the radiator fan and the engine block and can reach down to get them out
Is it possible to remove the tray on the underside and get access that way? If so can someone post a diagram? (I'm waiting on my workshop manual dvd to be shipped) and what tools I need?
Old May 2, 2017 | 12:57 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
The tray is very easy to remove. Should be a few 8mm hex bolts. You don't even to remove the entire panel or raise the car. The 4 bolts at the front should be enough to lower the panel a bit. Then reach in there and pull out the tool. Good luck.
Old May 2, 2017 | 04:52 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Lost a socket wrench in there once. It got stuck there till I did the Bix.
