How to Read O2 Sensor Data
Old May 4, 2017 | 04:39 PM
Joe Regester's Avatar
2005 C230
I am trying to get a P0240 code (low cat efficiency) cleared. Of course it might be related to it being a well used cat(200k miles), but it might be the O2 sensors.
I have a cheap ELM327 reader and use Torque both of which seem to work. I get a reading for O2 sensor bank 1-sensor 2 but not for sensor 1. I have replaced both sensors. Is this normal or am I missing something? Is there a better free option than Torque. Any ideas on what the O2 sensors should be reading?
Old May 5, 2017 | 02:14 AM
2005 C230
The problem I am concerned about is why can't I see what is going on with sensor #1.
Old May 5, 2017 | 04:10 PM
2005 C230
My fear is that it is the ECU that is buggard up and will need replacement. I can trend sensor 1 but it is always zero
Old May 6, 2017 | 03:32 AM
Russell Ormerod's Avatar
not a merc
Doubt its the ecu.
Old May 12, 2017 | 01:56 PM
kev95's Avatar
Mercedes-Benz CLK200K 2005
O2S1EQ is you upstream O2 sensor data. To better understand it, watch it as graph
Old Jun 27, 2017 | 09:32 PM
courtice_m's Avatar
2005 C230K Coupe
experiencing same thing bank 1, sensor 1 no signal/graff
throwing system too lean P0171 / P0170
have any luck?
Old Jun 27, 2017 | 11:58 PM
kev95's Avatar
have any luck?
Did you try to watch it with torque app? Did you choose "O2 Volts Bank 1 Sensor 1"?
To see sensor 1 graph then you should choose "O2 Sensor1 Equivalence Ratio" and you can see what your sensor is doing.
Old Jun 28, 2017 | 12:27 AM
courtice_m's Avatar
2005 C230K Coupe
O2 sensor
Thanks for the reply!
Yes using Torque app.
If chose 02 sensor bank 1 sensor 1 upper screen blank.
If chose 02 sensor bank 1 sensor 2 lower screen shows live Graff.
Did you end up solving your problem?
Old Jun 28, 2017 | 01:13 AM
kev95's Avatar
To see Sensor1 graph using torque app. Go menu - Add display - graph - choose " O2 Sensor1 Equivalence Ratio".
Yes, I solved my problem.
My P0170 and P0171 was solved after cleaning MAF with cleaner and during maf removal I found a problem with one airbox clamp. It wasnt tight anymore and it had and airleak because of that. Tightened clamp and my fuel trim was nice again.
My thread: https://mbworld.org/forums/clk-class...p0036-cel.html
Old Dec 19, 2017 | 09:26 PM
2005 C230
Thought I would post the long overdue resolution to this issue.
1) Torque was not reading correctly and when I tried another monitoring program it cleared the lack of that one reading.
2) After changing the O2 sensors the problem persisted thus I expected the old cat was failing
3) Bought a aftermarket CAT (needed one CARB rated, but was only listed for 2004 not 2005) but it fit fine. Got it for $400.
4) Breezed though the smog check, Has been working fine ever since. Yea!
