2001 c320 OBD2 doesn't see evap system
Old May 11, 2017 | 11:18 PM
DenisSlob4's Avatar
2001 Mercedes-Benz c320
I tried to pass emissions today and have no engine codes but failed the test because the evap light at the top is not on. I was hoping someone can tell me all the components that are in that system and their location so I can check that all the connectors are plugged in and if someone can provide a wiring diagram from the obd port for that system that would be great. Thank you.
Old May 12, 2017 | 02:08 AM
tjts1's Avatar
C320
Where are you located, different jurisdictions have different emissions requirements. Did the emissions person tell you that your evap readiness monitor had not set?
Old May 12, 2017 | 11:52 AM
DenisSlob4's Avatar
Portland, OR. The tech said that it could be an unplugged connector. (It's not pending, I didn't reset codes for at least a few hundred miles) The Evap system is not sending a signal to the odb2 port.
Old May 12, 2017 | 11:53 AM
DenisSlob4's Avatar
Originally Posted by Plutoe
Put your VIN in Startek WIS and do a search!
I was looking for free guides, not to pay $75 to just find part locations
Old May 12, 2017 | 02:48 PM
tjts1's Avatar
C320
That's really odd, i suspect it's a problem with the smog station. I would get a second opinion.
Old May 12, 2017 | 02:53 PM
DenisSlob4's Avatar
I thought it was an issue with their scanner as well so I got tried my own and same thing
