Turn signal stays on
I've done so far:
1. changed out the bulb - no change
2. tried the bulb screw on housing from the right side - no change
3. plugging the bulb and the screw socket to the right hand side - the socket and bulb works
4. checking the relay - it states "Headlamp flasher (i assume its the blinker) - electronic" I am not sure what that means... is it controlled by computers or just a relay?
5. I saw this "Light activation is by the SAM's themselves when they receive a signal on the CANBUS. They are electronically protected - no fuses." does that mean my SAM's having issues?
I've also checked link below and my fuse box looks nothing like it
http://www.mercedes.gen.in/mercedes-...ndicator-cure/
and here is the diagram of all the fuse boxes:
http://www.mercedesmedic.com/2001-20...gram-pictures/
Any help is appreciated.
I've done so far:
Also do you have a icarsoft mbII reader? Might give you more info to work with, I own and it does everything
No i do not have an icarsoft mbII I do have this generic OBC reader that connects to my phone and didn't give any error/codes. When I tried to pull log it just says "no codes are stored in ECU" if that's not the samething I'll pick one up.
I don't have this problem, but on my 2005 C240 my wiper will run non-stop when set to position 0 (i.e., off). If I set it to the 'Auto' setting it functions normally (as it should on the auto setting). I have been meaning to replace my multi-function switch but haven't gotten around to it. You need to remove the steering wheel to do it (not super difficult if you are handy - I've already done it once to replace my steering wheel).
Unfortunately there is no good way to test for a faulty multi-function switch, but your symptoms lead to me to further believe the circuitry in these switches can go bad causing strange symptoms. Good luck!
The turn signal (multifunction) stalk assembly only sends a signal like an on/off switch. There is no logic so to speak. Something that won't turn off is a SAM problem, not a stalk problem.
