2002 C230 AC not blowing cold
Old Jul 25, 2017 | 06:06 PM
mbismylife's Avatar
2002 Mercedes C230K
My car has been having lot of issues lately, the age seems to be catching up. I have successfully resolved all issues except the AC. Here is a description of the issue.
The AC blows hot. I tried to recharge it using the regular R134a can with a pressure gauge. When connected to the low pressure valve, the gauge needle went beyond red and showed full. No matter what I do, the AC does not take in any Freon from the can.
What must be the issue? i am going crazy in this heat with the AC blowing hot air.
Please help
Old Jul 25, 2017 | 06:38 PM
MacVidMB-V8's Avatar
W209, W124
Please help
You need compressor running to get it to take Freon.
Otherwise pressure equalizes and is higher than can.
Research is key here, worth doing right. Randomly jamming things when you don't know what you're doing can quickly move AC into "needs professional help' land.
Old Jul 25, 2017 | 06:47 PM
tjts1's Avatar
C320
Is the center of the AC pulley spinning when the engine is running?
Old Jul 25, 2017 | 10:39 PM
mbismylife's Avatar
2002 Mercedes C230K
I agree with you. Thanks for the heads up. will try to see some other threads related to similar issues.
Old Jul 25, 2017 | 10:41 PM
mbismylife's Avatar
2002 Mercedes C230K
I do see the pulley spinning even if the AC is off. I will try to also upload a video or picture soon just to make sure i am looking at the right pulley.
Old Jul 25, 2017 | 11:30 PM
tjts1's Avatar
C320
These cars don't have an AC clutch so the AC compressor should always be spinning with the engine even when the AC is switched off. The AC pulley is designed to break away from the belt pulley if the AC compressor is seized. Think of it as a fuse which would save your serpentine belt. If the center of the AC pulley is not spinning with the engine that means your AC compressor has failed and needs to be replaced.
Old Jul 27, 2017 | 10:22 PM
Kwikdog's Avatar
2005 C230 Coupe 6sp, Black/Black/BiX
Check the Evaporator Core Temperature Sensor.
I had a similar issue. Basically the temp sensor failed, and was reading that the core was -27 degrees. The computer thought that the evap core had frozen over and applied heat to attempt to melt the ice.
Its a bit awkward to replace, but not expensive.
