Transmission slips into neutral
Old Aug 27, 2017 | 11:57 PM
kelvinbarnes's Avatar
2005 C240 4Matic
Angry Transmission slips into neutral
My 2005 C240 4Matic slips into neutral after I coast down a hill (about 3/4 mile long). The other problem is that sometimes when I change to drive, it takes a while to actually go into gear so that the car can move.
Recently the shifter was changed after the car would not start (it was stuck in gear)
Any suggestions? The car has 222000 miles.
Old Feb 20, 2018 | 01:04 PM
2005 C240 4Matic
I found the solution to my problem. Hopefully my experience will help others.
The car was low on automatic transmission fluid. After adding transmission fluid the problem has gone away.
The car has over 230,000 miles so going forward I will check the fluid level at regular intervals. The pan looks like there might be a small leak so if the fluid levels drop in a short time I will repair the seal.
Old Feb 21, 2018 | 02:33 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Old thread, but good information. I can definitely attest to that weird transmssion shifting into neutral issue being caused by low fluid. I thought my transmission was about to go but a fluid change fixed the problem. The mechanic also found that the pilot bushing (I already had it replaced once) was leaking again. There's a 3rd version of this part.
Old Feb 21, 2018 | 02:31 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Just saw this, and immediately thought trans fluid. The downward angle was exacerbating the problem.
The bad news is that you may have fluid leaking into the transmission wire loom. OR the radiator.
Did you replace the orings on the trans connector? You need what Mercedes calls the 'Pilot bushing"
which is a totally erroneous name, its the orings with a plastic piece since they
don't sell the orings separately. Part number 2035400253.
