Putting in a different radiator fan or small clutch fan
Old Feb 20, 2018 | 01:15 PM
Skye168's Avatar
W203 C240
Is it okay if i put in a different radiator fan or put in a clutch fan to avoid higher temp ? Since my fan kicks in at 100 degrees it goes fast first and slow down then stop then after a minute same cycle goes on ... since my ac compressor is also i guess busted even if its new it wont accept refrigerant
i just want to use my car without overheat issues since i do late night driving to cure my depression so wanna do some remedies and do on the aircon issues later on
Old Feb 20, 2018 | 01:32 PM
tjts1's Avatar
C320
Did you read any of the responses to your previous dozen posts on the subject? Your fan behavior is perfectly normal. It's supposed to turn on at 100c then cycle up and down as needed.
Old Feb 20, 2018 | 03:58 PM
efzauner's Avatar
2005 C240 2011 R350
if you insist on doing this why not just a manual switch to override the thermostat? Thermostat is probably normally open, and closed when it hits 100C. If you put a switch in parallel, you can activate it manually from the cockpit.
Old Feb 20, 2018 | 05:37 PM
Skye168's Avatar
W203 C240
its turns at 100 at goes down to 95 then off and goes at 100 again ... and you just dont probably know how hot it is here in the philippines and the traffic condition
i just want to avoid breaking down or having a head gasket failure and besides even if i turn on the climate control still same cycle as my brand new ac compressor release suction of refrigerant it cannot fill to spec
Old Feb 20, 2018 | 05:39 PM
Skye168's Avatar
W203 C240
is it something like fooling the fan to open at 85 degrees like my w210 m112 does before fan engages at 85-89
Old Feb 20, 2018 | 05:47 PM
Skye168's Avatar
W203 C240
Old Feb 20, 2018 | 06:53 PM
tjts1's Avatar
C320
Ever been to Vegas in August?
https://i.imgur.com/C6RyAMm.jpg
Old Feb 20, 2018 | 07:01 PM
Skye168's Avatar
W203 C240
but probably your engine temp is around 87-89 degrees Celcius judging in the guage its a w210
Old Feb 20, 2018 | 07:05 PM
tjts1's Avatar
C320
And my w203 perfectly fine in the same 40c+ climate.
https://imgur.com/04ixPkJ
Old Feb 21, 2018 | 02:47 PM
Skye168's Avatar
W203 C240
you are in a no danger zone while my temp is almost at 100 yours is only halfway
