What's your rear camber? mine is -1.7 vs -1.4 spec.
Had a wheel alignment done.
ALL OK except rear camber.
spec is max -1.4,
my left is -1.1 but right is at -1.7
toe in is 0.28 left and 0.37 on right (no adjustment done)
spec is max 0.52
I had and probably still have lots of inner rear tire wear.
I was really expecting a big toe in problem in the rear.
Is the slightly off right rear camber going to cause this?
is it worth getting a rear camber kit to fix this?
The rear is quite solid, would changing rear parts fix this?
I also had it done with a full tank of gas. I suspect that half full would have given a bit less camber?
