Does a 04 c240 have a brake light switch?
Old Sep 23, 2017 | 03:41 PM
Amott1989's Avatar
C240
If so where .. I think I read it's under the master brake cylinder?
Help plz ..
Car is stuck in reverse
Old Sep 25, 2017 | 03:42 PM
Amott1989's Avatar
C240
Does that work ?
Old Sep 25, 2017 | 05:37 PM
Amott1989's Avatar
C240
Originally Posted by Plutoe
I could not find any evidence of a BLS on the brake pedal------what is your issue or did you have a slow afternoon!
Yeah it's not there that is where I looked.. it was stuck in reverse but now it's fixed.. .. do you have a reference you use for finding stuff out about MB you could share? I have a 04 c240 and have a esp issue every once n a while .. it only happens though approaching a stop light or coasting under 30 miles per hour I then have to slow way down put it in neutral turn it off and back on and then into drive and it works fine but if I could find a way to solve this problem that would be ideal
Old Sep 26, 2017 | 04:49 PM
Russell Ormerod's Avatar
not a merc
Well u not explaining the ESP issue? What fault codes?
The gear selector needs to see a brake pressure value before it will allow it to move out of park. That signal comes via CAN from the ESP. Are there ESP faults or total loss of comms?
