Key won’t turn HELP 😁
Old Sep 27, 2017 | 09:10 AM
weeperer's Avatar
mercedes clc 200
Hello. I have MB clc 200 kompressor 2001 that the battery died on, when it died i forgot the key in on position for a time. have now replaced the battery but when i put the key in the ignition it will not turn, but the steeringwheel lock turns off, have replaced the battery in the key aslo with no luck. Anyone who has a clue for what it can be?
Old Sep 27, 2017 | 09:56 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
If you have the second key, try with that second key.
Old Sep 27, 2017 | 11:01 AM
weeperer's Avatar
mercedes clc 200
Only have the one key 😖
Old Sep 27, 2017 | 03:11 PM
Russell Ormerod's Avatar
not a merc
Does it lock and unlock? Read actual values for drive authorisation in EZS to see what is missing
Old Dec 2, 2023 | 01:18 PM
Badami1982's Avatar
1999 e320 4MATIC wagon
Similar issue
Hi frobi and all,
I have a similar issue in 1999 e320 wagon. It was cold in my city and in the evening the car wouldn’t start nor make usual click when I inserted my key. The steering wheel was locked, the gear selector was locked, though interior and dash lights did come on. I changed key battery and no success. It did start with a jump start, so I changed to a new fully charged car battery, and now it either starts on 3rd attempt sometimes, or I insert the key into the ignition, and press the KEY door lock button twice, and THEN the key turns to start the ignition. Any suggestions?
I only have one key.
