Brake warning message
Old Apr 12, 2002 | 12:32 PM
harpax's Avatar
2002 C230K Coupe
Does c-coupe have warning message that tell you "change brake pads"?
Cause i was browsing CLK forum and one guy mentioned about the change brake pad warning message.
Old Apr 12, 2002 | 03:13 PM
Lynn's Avatar
Re: Brake warning message
The c-coupe does have pad wear sensors, and there will be a warning about worn pads. However, if you use Porterfield or some other aftermarket pads, you will lose this feature. Those pads don't have provisions for mounting the sensors.
