No gear detected. Engine don't start after transmission module repair
Old Nov 22, 2017 | 09:26 AM
albrechtmc's Avatar
Mercedes B180 year 2010
Mercedes B180 year 2010. My car needed an transmission module repair to fix RPM Sensor signal. Now, the panel doesn't show gear selection and position and the engine don't start. Any ideas about what's probably happening? Thanks a lot Marcelo. from Brazil
Old Nov 22, 2017 | 09:28 AM
ItalianJoe1's Avatar
2003 CL 600
Did you have the initial startup programming performed properly?
Old Nov 22, 2017 | 09:33 AM
albrechtmc's Avatar
Hi ItalianJoe1,
I don't have information about how to perform the initial startup programming? Do you know the steps to perform this procedure?
Old Nov 22, 2017 | 10:23 AM
2003 CL 600
Connect an SDS, go into the VGS module, then adaptations, then initial startup. Must be done by a dealership.
