220cdi starting problem
Old Dec 5, 2017 | 11:13 AM
miofan's Avatar
w203.208 220cdi 143ps
Hi I had a big problem with my w203.208 220cdi '04 model, The car had an issue with at gearbox conductor plate, I changed it, all code erased, tested no more faulty codes but the car wont crank, wont start. Tried my second key, same result. How can I check the starter relay, before try to change the starter soleonid or starter motor. I hear from the engine bay, the ac pump whinning, so possible the fuel line is ok. I was by petrol staion and fuelled full the tank, than happened the starting problem.
And when I checked first with WOW and Würth OBD program, by the petrol station, the battery voltage was under 12 volt. Before I forgot to switch off the parking light. Maybe a bad regulator? Why dont have any codes than?
Old Dec 5, 2017 | 12:59 PM
miofan's Avatar
Fortunately I found the solution, when I checked first time the fuse box I saw just two 15 and 20A fuses. I have read again lot of discussion, I found a threat where my hero said fuse 52 need to replace. And I checked again and found a fuse without white number (it was replaced before) and she is working! I am very happy thanks to everybody who wrote something about wont starting issue. My next job is replace the starter motor...
