2003 C240 Periodically will not start
Find a better repair shop, you're being ripped off with that quote. I found a pump with sender on Amazon for $58. It took me an hour to replace in my garage with basic tools. It helps if the tank is mostly empty. The filter with built in pressure regulator was an additional $25.
The guy I spoke to thinks that I need a wiring part in addition to the Fuel Sending Unit. He says that the bad connection is on the BODY SIDE. My question is: with all the wires and hoses coming out of the Sending Unit, do I need to order another wire? I feel as if the answer is no...Thanks in advance.
http://fusesdiagram.com/mercedes/fus...edes-w203.html
A question on the wiring harness which was shorted: do you think this looks like factory wiring? If not, this issue happened to the previous owner of the car...
And order all new terminals too
