blondie92110
Did you buy the car new? Wondering if it's caused an improper repair from a previous owner.
Also, what are the codes from each of the mechanics?
Are you getting a used or a rebuilt engine?
Imho, any M217 engine should have a number of items rebuilt/replaced, if they haven't by now.
The timing chain is a POS. And, the intake valves in the head, in the American Version, get oil caked on them from lack of proper oil control resulting from the supercharger.
There are a few rubber hoses that deteriorate from age, and poor quailty. The back of the engine oil pump also leaks after time/mileage.
"Sounds" like your engine had one or two bad cam adjusters. And, maybe the cam may have needed to be replaced, because of the bad adjusters.
So, yes, figure a few thousand dollars to fix the cam adjusters and/or cams.
However, a rebuilt engine alone cost more than the above repair. Then, add in labor to remove, install, etc. My guess, is that even if it was done by an an independent, verses the Dealer, the cost would easily exceed $6K.
On the other hand, a used engine cam be had pretty cheaply. One reason is because of the issues I mentioned above. A used engine is just playing more Russian Roulette with a low-cost design that was purposely designed to save on the cost at the tradeoff of not lasting a long time (mileage or years).
Mechanical and electronic designs very often have to tradeoff cost verses "longevity". Military, Aeronautics, and Space all cost a lot largely because of the required reliability (and preventive maintenance).
Fwiw, I knew that I was going to "rebuild"/replace a lot of engine components when I bought my C230. It's all about maintenance. And, where needed - upgrading.
Good Luck!
