Crankshaft sensor Location mercedes benz c230 kompressor 2005 M271
Old Jan 5, 2018 | 12:26 PM
pablow6554's Avatar
mercedez benz c230 kompressor 2005
Crankshaft sensor Location if you have picture it would help.I got a new battery then a new starter because the starter was bad it would crank it work for a week.Now this week i was driving it perfect and it stop so i tryed cranking it again waited a while then it crank and it turn off on the way home it continue on doing this 3 or 4 times now.it would crank but not start.I believe it the crankshaft sensor can you guy give me the location of it cant find it.Also the relay and the fuse for the crankshaft sensor if you can thanks.
Old Jan 5, 2018 | 09:50 PM
RWDlifer's Avatar
2005 C230K SS
The crank sensor is on the driver side under the supercharger. Easier to access from below unless you remove intake and S/C. You can't miss it. No relay or fuse for it.
Old Nov 21, 2018 | 12:59 AM
kad783's Avatar
2003 C230 Kompressor (W203)
Did you end up changing the crankshaft sensor? if so how did you get to it? I tried looking from above and under the car but did not see it
Old Nov 21, 2018 | 06:39 PM
kad783's Avatar
ok found it, really tight down there tho but managed to do it!
Here is a pic of where it is located on the engine I found online, so the upper left side of the engine flywheel, under the oil filter.
