MAF SENSOR/BODY
Old Jan 23, 2018 | 11:12 PM
courtice_m's Avatar
2005 C230K Coupe
MAF SENSOR/BODY
Hello,
Hoping to get you guys comments/recommendations.
I've a 2005 C230 Kompressor Coupe 1.8
I be needing a MAF sensor, but dealership ridiculous price, so but to my knowledge the MAF sensor consists of of a body plus the sensor insert.
If the sensor itself would be available on its own there is no need to replace the entire body housing.
So my Q: is does anyone know of anywhere that might sell just the sensor insert?
Also has anyone had any luck with lower priced MAF sensors?
Im experiencing a P0171 system too lean, and using the Torque App the precat 02 sensor shows zero voltage reading.
I've replaced both 02 sensors, camshaft magnetic sensors?pigtail harness, there are no vacuum leaks(had the entire air cleaner housing off and inspected crankcase hoses etc and everything is fine.
Engine runs great,no lag, no misfire, runs smooth etc, but fuel consumption shot up high + the engine light on - P0171 system too lean.
Would greatly appreciate any help/comments if you guys experienced same etc?
Not taking it to Dealership as i might just as well bend over and say "GIVE IT TO ME"
I live in Canada, vehicle has 369,000 Klm
Old Jan 24, 2018 | 12:24 AM
tjts1's Avatar
C320
Before replacing your MAF sensor, check your fuel pressure. Should be around 56psi at all times.
Old Jan 24, 2018 | 05:21 AM
courtice_m's Avatar
2005 C230K Coupe
Fuel pump was changed (Bosch) four months ago for other reasons, but this problem was also there prior to that.
Thanx anyways
Old Jan 24, 2018 | 10:39 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
check out FCPeuro.com for good prices on parts for your car. Since you also have the older kompressor m271 engine, you also need to check whether your crankcase vent hoses are torn causing an air leak/lean condition.
Old Jan 24, 2018 | 01:17 PM
tjts1's Avatar
C320
If your MAF was bad you would notice drivability problems.
Old Jan 25, 2018 | 08:14 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
If you are getting no signal from your 02 and you have a lean code I think you found your problem
Old Jan 27, 2018 | 05:28 AM
RothnerD's Avatar
W203 C180k 2005
MAF sensor picture
Hi there, can someone please send me a clear pic for the m271 MAF sensor, aspecially the inside where the actual sensor is. Please
Old Jan 27, 2018 | 11:15 PM
courtice_m's Avatar
2005 C230K Coupe
Update
Ordered MAF sensor from Dealership $500
No change, still running lean P0171
Precat 02 still zero voltage reading using Torque Pro
Would anyone perhaps have access to a wiring diagram for the VEHICLES Precat 02 connector
Old Jan 28, 2018 | 07:45 AM
tjts1's Avatar
C320
Ouch!
Again, check your fuel pressure. In order to have the correct fuel pressure you need a good fuel pump AND and good fuel pressure regulator.
Old Jan 28, 2018 | 08:55 AM
courtice_m's Avatar
2005 C230K Coupe
MAF
Originally Posted by tjts1
Ouch!
Thanx again tjts
but as I mentioned earlier the Bosch fuel pump is fairly new.
It's actually the second pump as the first one was reading incorrect fuel level.
I'm starting to suspect maybe engine wiring harness or the ECU
Old Feb 2, 2018 | 01:02 AM
ppbw123's Avatar
2005 c230 kompressor
Try to replace the air filter with a genuine or better brand - in response to reset the p0171 code.
Old Feb 2, 2018 | 09:06 AM
insame1's Avatar
So am i crazy here? You have an obvious issue with the 02 sensor but you bought a MAF instead? I think the problem is that you haven't sent me $500 bucks. I bet it will work like a charm after that.
Old Feb 2, 2018 | 03:06 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Sooooo.....
a. Get a iCarsoft code reader. Generic codes are useless. Was
fighting the 0171 too lean code for a long time, till I read it 1st with
Carsoft and then paid a guy $40 to get a printout on
SDS. Both said tthe same thing.
Hot film Mass Air Flow sensor: Short circuit
b. I purchased the Bremi MAF from RM European online for like $100 bucks or so.
I will say I did have a problem with it, and had to send it back under warranty for a replacement,
the glue came undone and the insert was hanging out the side. I coulda just glued but I got a new one for free.
c. I spend some time in the R170 forum, which has the same engine as mine.
And those guys are using Pierburg MAF inserts. Can't tell you exactly where to get one,
but look around.
d. Insame, didn't he say he replaced the 02 sensors?
Oh, wiat I see he got one, and might be a wiring issue.
e. Call 1800Mercedes and see if they still sell the service DVD, it has everything including wiring diagrams for
about $60.
Old Feb 3, 2018 | 04:42 PM
Russell Ormerod's Avatar
not a merc
That's what ****ty diagnostics gets you? Change your diagnostic tool not the parts on the car.
Old Sep 4, 2019 | 05:18 PM
Update: BREMI MAF failed again, same problem.
There will be no 3rd time.
Looking for best price on the VDO unit.
Anyone use the Hella one?
