P0016 code BUT balance shaft sprocket fine
Old Feb 26, 2018 | 05:34 PM
Jay Knudson's Avatar
C230
Hoping someone has some ideas because I'm stumped at this point. Have 2007 C230 with engine outside the balance shaft gear problem range. In addition, I ran a bore-scope into the engine and confirmed the balance shaft sprocket is fine as well as the crankshaft sprocket. I keep getting a P0016 error code and occasional P0305. (I DO NOT ever get a P0017 code) I'll clear the codes, drive the car, no CEL while driving. Turn the car off. When I restart the car the CEL will turn on with at least the P0016 within driving 10 ft. While driving, the car runs smooth, however at a stop sign it does idle rough.
I've replace all 4 camshaft sensors and camshaft magnets. To do the bore-scope I had to remove the camshaft cover. The alignment marks looked good on passenger side and the chain didn't feel loose.
The only thing I can figure at this point is I have some issue with the ECU? Any thoughts or suggestions?
Thanks in advance!
Old Feb 28, 2018 | 02:20 PM
Russell Ormerod's Avatar
not a merc
Do all the circle markings line up with the sensor holes at 305 degrees?
Then carry out camshaft adaptation with xentry.
Old Jul 7, 2018 | 01:42 PM
Eric D.'s Avatar
C230
Scoping the balance shaft sprocket
Thanks in advance!
Jay,
Can you tell me what diameter borescope you used?
